ArduIMU Firmware 1.2
Hi there! I'm happy to announce the new ArduIMU firmware and ground station, you can download it from here:http://code.google.com/p/ardu-imu/downloads/listWhat new in the firmware:-You can now select DCM, Euler Angles our both.-Enable GPS output data.-Some minor bug fixed.-The orientation of the gyros and accels are now corrected.Whats new in the Ground Station:-Now the Baud speed is set to 38400 bps to be compatible with ArduPilot uBlox GPS.-You can see now the Euler Angles generated on the uController.-Better debug tools.-GPS information.-Raw Data.What i'm doing now:-Designing new PCB's.-Improving ArduPilot code.-FPV testing with ArduPilot.-Taking care of the business and shipments.-Improving the Store.-Going to School.-Trying to answer some emails.-Always trying to get a beer and some Sushi..Please be patient, I'm always working for you! ;-) Thanks for you support!
  • Hello,
    I want to connect arduIMU to arduPilot.
    ny suggestion about the best way to connect them ?
  • jordi! where is my sensors man. check your inboxx
    Ken,
    Sorry i forgot to add the 360 compensation... But yes the YAW is correct. Also i forgot to correct another bug report by Doug Weibel (thanks!). but only affects ground speed display... :/ never is perfect..
    Khalid, you're going to have to give us more info than that. Please describe exactly what you've tried and what you're expecting.
  • What i'm doing now:
    -Going to School.
    mmm hu hu hu get enough sleep...
  • Woohoo! now we are cooking with gas!
    Only one glitch so far: What is the expected output for yaw? Do I misunderstand the output? Roll and pitch seem to be working fine. But yaw swings fairly quickly from 0 to +/-179.9 degrees and stays there. If I yaw the device it will react, but then, even in the new position yaw clocks over to 179 again. At first I thought it was because I had no GPS connection. So I hard coded both ground speed and 3d speed to 10.0, and ground course to (anything). Still does it. What am I missing about this?
  • Still can't get it to work. The lights flash and then nothing.
  • @Doug
    Thanks a lot !
    @CLT - With v1.2 you have some choice of data to be sent out. The default is euler angles. Change the flag to have the DCM matrix info sent out as well and groundtest.vi will work.
  • Hello!
    I see data arriving in Serial_server.vi panel (thanks to viky's code).
    But I don't see anything in groundtest !
    Could you help ?
    Thanks,
