- All the ArduPilot 1.0 functions: programmable 3D waypoints; return-to-launch mode, in-flight reset ability, fully programmable actions at waypoint and totally expandable board.
- Now integrates the stabilization and navigation functions, eliminating the need for a FMA Co-Pilot and vastly improving waypoint tracking
- Controls elevator and ailerons/rudder. Throttle control coming in 2.1
- "Fly-by-wire" mode stabilizes the aircraft in RC mode, duplicating the function of the FMA Co-Pilot
- Stores home waypoints and sensor calibration in EEPROM, so they are retained even in the case of a system restart
- Controls altitude with the elevator, vastly improving performance in wind
- Currently optimized for the three-channel EasyStar. Versions have also been tested on Funjet and four-channel Superstar (code coming soon)
- Simple in-field calibration process
- Can use any thermopile XY sensors (default settings are for the FMA sensor, but Paparazzi, AttoPilot and custom sensors can also be used)
- Currently supports the EM406 GPS. Support for Locosys and Ublox GPS modules coming soon
- Uses "chained PID loops" to combine the stabilization and navigation functions seamlessly
- ArduPilot board ($24.95)
- EM406 GPS module ($59.95)
- A FMA XY sensor ($42.95; if you already have a FMA Co-Pilot, you can use its sensor). If you're buying the FMA sensor by itself, you'll also need to purchase a cable.
- A FTDI cable, such as the Sparkfun ($13.95) or Adafruit ($20) ones
- ArduPilot 2.0 code (Free)
- Uses Z sensor for self-calibration in the field
- Uses small desktop app to load ArduPilot settings and waypoints, without having to work with code
- Adds throttle to altitude control, improving accuracy and wind performance
This may be a silly question but in your IR conversion to degrees do you assume that the midpoint is 511? Would it not be better to calculate an average IR value in the level position and reference to this instead?
Thanks for your time.
Sirk
better fly ?
I am brand new to this so these might be silly questions answered elsewhere.
My Ardupilot board arrived and I have assembled it, hooked it up and am trying to download the Ardupilot 2 code, but I am confused by the files I am downloading off the net.
When I get the Ardupilot 2.zip it expands to ArduPilot_EasyStar_WP which is beta 1,0 in the code header.
Is this correct?
Due to this confusion I may have inadvertently installed Ardupilot 1 at some stage, will this upset things trying to install 2.0 over the top of 1?
Also, the led ON the GPS is always blinking, even when I have a blue lock led lit. According to the led page this led should not be lit at all??? but I can find no reference to "if the GPS led blinks then ....."
I hope someone can indicate what simple mistakes I must have made.
I have installed the FMA sensor and run the sensortest and all looks well, I get the changing figures when it is moved.
The leds respond to the mode switch from the transmitter.
Also the Out2 servo seems to pulse every 10 seconds or so.
Help! I am a bit lost at this stage as to what to do next.
If you set the throttle to a medium setting, those problems don't arise. But we will be adding throttle control to future versions of ArduPilot. It's just not a high priority, because it works fine in most conditions without it.
1
2
3
4
5
of 11 Next
