Ardupilot 2.5 Beta
This is a quick note to let everyone know that Ardupilot 2.5 is feature complete and can be downloaded via SVN. If you're on Windows, use TourtiseSVN and if you're on a OS X like me, try Versions. The code is located here.Once the Beta feedback is in I'll post a zip file of the final version. Information about using SVN can be found on the web. Please post any issues in this blog post, and I'll fix them immediately and re-upload.I'm also building a wiki manual to help with the configuration, but it's an early work in progress. I'll write a lot more this week, but there should be enough content up there to get you going.Use the Airframe tester to configure your new 2.5 header file and familiarize yourself with the startup sequence. Don't use the old 2.4 file, except to copy over your old gain settings. I've tried to keep as many of the values the same, but many values are new as well.By Default the control switch settings are 1 - manual, 2 - Autopilot, 3 - Stabilize. Feel free to change them to whatever you like.Good luck,Jasonp.s. Who thinks Ardupilot needs a logo?
    I'm debugging it on the scope now. Will let you know.
    Okay, I've now tried it on three ArduPilots and planes. On the FASST R606FS receivers, it overdrives the servos and they strip. On the R6106HFC, to does the same thing (drives the elevator to the extreme deflection) but for some reason doesn't push the servo past the endstops. That may have more to do with differences in the servos used than the receivers.
    Jason, no joy, I'm afraid (although the serial terminal no longer shows input values. Same elevator servo jamming on startup and when RTL or Waypoint is enabled.
    Here is the serial stream in manual mode:
    And here's the serial stream in RTL mode:
    Hi Christopher,
    For now could you just send me a fix and I'll verify it works with the system and then upload it. We're on a tight schedule for releasing 2.5
    Thanks,
    Jason
  • I've spotted a bug in the uBlox GPS decoding which means that corrupt messages are not rejected.
    If you are happy to add me to the google code project committers then I will gladly submit a fix - which would be the easiest - if you don't want more people on the project let me know and I'll explain the issue (two compensating bugs at present).
    You can see an example of similar code I'm working on in "http://code.google.com/p/ardunxt/"
    wow, good to hear. Be sure and grab the latest version. We just made some bug fixes!
    Great. I'm heading out for a few hours but will test tonight...., thanks!
    That helps. I think I tracked that one down.
    In the radio init, the ch2_trim value is being set too low. Most likely this is caused by the filter not being warmed up properly. There is a loop to do this, but I found that it didn't have a 20ms delay on it when reading the radio. That made the loop run too fast. I uploaded a fix.
    Thanks for testing it!
    Jason
    http://down.In/
    See related links to what you are looking for.
    ch2_min is reading 150
    Jason, I am not seeing this issue with radio type 1. I am heading out to test again and will double check.
