Here's what I hope is the final release.
As the new Manual gets formatted, you can view it at: http://code.google.com/p/ardupilot/wiki/ArduPilot25
Until the content is finally moved over the 2.4 manual is still a great resource.
Ardupilot_25_RC2.zip
Bonus - If you look check out the Waypoint_writer_25.pde file in the test suite, you can upload relative waypoints. This isn't supported in the config tool yet.
Jason
UPDATE -
A lot of people were having trouble with the GPS code and LEDs. I reworked the GPS parsers today to iron out some things. They were nothing that would interfere with flight, but I highly recommend using this new version. I've also added the ability to scale down your plane's roll based on airspeed. This should help planes that turn faster when they go slower. We may tweak this a bit in the future, so I'm looking for feedback on it. Note you can always turn it off in your header file with this line:
//6-4
#define AIRSPEED_TURN_P 1
see the header file for more instructions
You don't need the throttle failsafe to fly. You can set your radio to change the control switch to the RTL position on failsafe. It's just a limitation on certain radios that makes you need to use the throttle for failsafe.
My Futaba 7C radio will only output this way and that's the whole reason this feature is there.
Jason - What ESCs you suggest. And how to know PWM values for each ESCs?
If someone wants to pitch in I can give them a "to do" list for the parser. Mostly we need to change it to a non-blocking parser so it doesn't bog down the IMU and we need to add a few flags. Then we will see how much time it takes to process a full message when it hits and maybe change the parser so it takes two passes through to complete work on a message to reduce the time it adds to the IMU loop.
My first concern is the radio PWM values seem low and/or incorrect. Are you using the Spektrum receiver?
Can you look at the radio tester in the RC2 folder and load that? it should output the raw PWM values. Ch1 and Ch2 should be in the mid 1000 to 2000 range.
Move the sticks around and send me that log. Thanks!
Everything looks and is behaving what I would say as normal from your log except that radio issue. The failsafe is being called while you're at the bench probably and your distance to home is showing up as a very low number. I have that error checker there to find bad GPS calculations. That seems to be behaving correctly although I will probably disable it in the final.
Jason
I am using DX-7 and uBlox GPS...
1st error is probably is a set up issue I missed. How should I start ...here is my log and comments
Init Ardupilot 2.5.0
wp_total 4
options 1000
wp_radius 33
Startup: Ground (it pauses here until I mess with sticks.. what should I do to start.. next
Radio Trim error ( this is reported every start up.....)
R:880 E:954 T:1199
Wait for GPS
Still Waiting: No Valid Fix
Still Waiting: No Valid Fix... (then gps lock..)
Loaded WP index:1
prev_WP: 388302109 -1048121633 182811
next_WP: 388315180 -1048023610 188811
wp_total: 4
home: 388302100 -1048121630 182800
wp #1 388315180 -1048023610 6000
wp #2 388293190 -1048023070 6000
wp #3 388293280 -1048032830 6000
wp #4 388303980 -1048032940 6000
Reading radio limits:
Move sticks to: upper right and lower Left.
To Continue, hold the stick in the corner for 2 seconds.
R:880 E:954 T:1199
Remove Safety Flag
Remove Safety Flag
Remove Safety Flag.... ( OK ready to go...)
Remove Safety Flag
##0| MANUAL
Ready to FLY.
!!!LAT:38830267,LON:-104812139,SPD:0,CRT:0,ALT:0,ALH:1888,CRS:306,BER:0,WPN:1,DST:0,BTV:8583079,RSP:0,***
+++ASP:0,THH:92,RLL:11,PCH:-29,***
+++ASP:0,THH:73,RLL:11,PCH:-29,***
+++ASP:0,THH:50,RLL:11,PCH:-29,***
!!!LAT:38830261,LON:-104812136,SPD:0,CRT:0,ALT:0,ALH:1888,CRS:306,BER:0,WPN:1,DST:0,BTV:8598246,RSP:0,***
+++ASP:0,THH:33,RLL:11,PCH:-29,***
+++ASP:0,THH:24,RLL:11,PCH:-29,***
!!!LAT:38830260,LON:-104812136,SPD:0,CRT:0,ALT:0,ALH:1888,CRS:306,BER:0,WPN:1,DST:0,BTV:8608159,RSP:0,***
+++ASP:0,THH:25,RLL:11,PCH:-29,***
*** FAILSAFE DETECTED ***
Loaded WP index:0
prev_WP: 388302609 -1048121365 183963
next_WP: 388302680 -1048121480 367855
##6| RTL
****FAILSAFE ON******
!!!LAT:38830262,LON:-104812138,SPD:0,CRT:0,ALT:0,ALH:1839,CRS:306,BER:0,WPN:0,DST:0,BTV:8618044,RSP:0,***
wp_distance error, loc: 388302620, -1048121385 next_WP 388302680, -1048121480
( this error due to home set to LAT xxx,LON xxx 182500 ???)......
After fine tuning of mixing of Gear to Throttle and turning the failsafe on during stick calibration.
I got this
Init Ardupilot 2.5.0_rc2
wp_total 4
options 1000
wp_radius 33
Startup: Ground
Radio Trim error
R:919 E:856 T:888
Wait for GPS
Loaded WP index:1
prev_WP: 388302574 -1048121231 182566
next_WP: 388315180 -1048023610 188566
wp_total: 4
home: 388302570 -1048121230 182500
R:919 E:856 T:888
Remove Safety Flag
Remove Safety Flag
and
+++ASP:-1,THH:25,RLL:-24,PCH:4,***
Loaded WP index:0
prev_WP: 388303057 -1048120817 182669
next_WP: 388302810 -1048120780 365027
##6| RTL
Reached WP:0
##7| LOITER
!!!LAT:38830305,LON:-104812083,SPD:0,CRT:0,ALT:1,ALH:1826,CRS:0,BER:173,WPN:0,DST:2,BTV:7132593,RSP:8,***
attached logsAP_R2C_BlueStik_DX-7_logArdupilot 2.5.0_rc2_log
Very close to a working system, Please advise...
Thanks again Jason...
Can you pm me I'm still having gps issues.
1
2
3
4
5
of 12 Next
