Here's what I hope is the final release.
As the new Manual gets formatted, you can view it at: http://code.google.com/p/ardupilot/wiki/ArduPilot25
Until the content is finally moved over the 2.4 manual is still a great resource.
Ardupilot_25_RC2.zip
Bonus - If you look check out the Waypoint_writer_25.pde file in the test suite, you can upload relative waypoints. This isn't supported in the config tool yet.
Jason
UPDATE -
A lot of people were having trouble with the GPS code and LEDs. I reworked the GPS parsers today to iron out some things. They were nothing that would interfere with flight, but I highly recommend using this new version. I've also added the ability to scale down your plane's roll based on airspeed. This should help planes that turn faster when they go slower. We may tweak this a bit in the future, so I'm looking for feedback on it. Note you can always turn it off in your header file with this line:
//6-4
#define AIRSPEED_TURN_P 1
see the header file for more instructions
I can get the failsafe message when I go through initial setup with half throttle, but when I reset the Ardupilot it goes normal again. so what should I do?
Also, you can change your plane's turn radius in the header file. Looks good!
Jason
tried your last svn in debug mode (still snowing here) with these waypoints, a bit far away than before.
Thisi is the config
and this is the plot of the debug.
Nice, didn't?
Have a nice day
marco
this is the site:
http://www.tchartdev.com
I will put more distance between waypoints.
Unfortunately it is still snowing here and will do a few tests in debug mode.
Found out this to trace waypoints:
then click on csv2klm
It is free, very easy to convert Ardu telemetry to csv .
This is the result:
I am using the latest svn (Revision r497). Is it correct?
Have a nice day
marco
> ArduIMU will be supported in 2.5.1. Doug is busy with that right now and we'll have that ready soon.
will it be possible to use ArduIMU with NMEA (Remzibi's) GPS ?
I've read somewhere there is a performance issue with such setup ?
