Please, a colleague, you can upload to the forum, a diagram of connections Ardupilot with sensors xy, z pressure sensor and confirm that the soft version of the 2.1
Grateful
Andres
hello again,.my tricopter uses 3 gyros plugged into escs which run the motors, a 4th gyro controls the rudder via a servo. on the rx i use the rudder channel, the aile, elev and an aux channel ( throttle is controlled by pitch) will I be able to use ardupilot? all I want to do is have the tricopter hold at a given place and altitude for aerial photography and a return to home feature.. Many thanks for any input.. Josh
Is it possible to do all communications with just xbees? As in no R/C radio. The xbee would transmit control, waypoints and send back telemetry and gps?
Yes, it's easy to control two other servos. Just connect their signal lines to a spare digital pin and use our servo routine to control that. That's what we do with ArduPilot 2.1 and up, which supports three outputs (the third is throttle)
Is there a flowchart of 2.1.1 ? Or an explanation other than code comments ?
Grateful
Andres
