Please, a colleague, you can upload to the forum, a diagram of connections Ardupilot with sensors xy, z pressure sensor and confirm that the soft version of the 2.1
Grateful
Andres
hello again,.my tricopter uses 3 gyros plugged into escs which run the motors, a 4th gyro controls the rudder via a servo. on the rx i use the rudder channel, the aile, elev and an aux channel ( throttle is controlled by pitch) will I be able to use ardupilot? all I want to do is have the tricopter hold at a given place and altitude for aerial photography and a return to home feature.. Many thanks for any input.. Josh
Yes, it's easy to control two other servos. Just connect their signal lines to a spare digital pin and use our servo routine to control that. That's what we do with ArduPilot 2.1 and up, which supports three outputs (the third is throttle)
hi... i'm a newbie in embedded electronics and am very happy to join... =)
thanks for tweaking the board to enable hardware pwm...
i have a crazy idea of using an ArduPilot...
in the setup it shows two servos in the output pin...
i would presume that ArduPilot could control those two servos to
automatically steer the plane...
it's probably a stupid question, but i would like to know if two extra
servos could be controlled by ArduPilot automatically just like the
way it controls the first two servos... therefore automatically controlling
all 4 servos instead of just two...
the answer is probably in the documentation or in the code, I will check
them both later... i just started using Arduino two weeks ago and started
coding C as well... i'm not even sure if that's what u call the language for
Arduino..
Is there a flowchart of 2.1.1 ? Or an explanation other than code comments ?
Grateful
Andres
Arduino..
let me know... thanks..
-AludrA
36
37
38
39
40
of 62 Next
