ArduPilot (Legacy) main page
3689315381?profile=original
[This original ArduPilot board, now called the "Legacy ArduPilot" is no longer produced or officially supported by the DIY Drones dev team, and this page is maintained just for historic reasons. However, there are still many users of it out there and it still works fine. The user group for Legacy ArduPilot users, for both thermopile and IMU use, is here.]
ArduPilot is a full-featured autopilot based on the Arduino open-source hardware platform. It uses infrared (thermopile) sensors or an IMU for stabilization and GPS for navigation. It is the autopilot used to win the 2009 Sparkfun Autonomous Vehicle Competition.
The hardware is available from Sparkfun for $24.95. An expansion board ("Shield") kits that includes an airspeed sensor, a 3.3v power regulator for 3.3v GPS modules and other sensors and cables and connectors for easy attachment of the XY and Z sensors, is available from our own store for $57.20.
User f
ArduPilot features include:
  • Can be used for an autonomous aircraft, car or boat.
  • Built-in hardware failsafe that uses a separate circuit (multiplexer chip and ATTiny processor) to transfer control from the RC system to the autopilot and back again. Includes ability to reboot the main processor in mid-flight.
  • Multiple 3D waypoints (limited only by memory)
  • Altitude controlled with the elevator and throttle
  • Comes with a 6-pin GPS connector for the 4Hz uBlox5 or 1hz EM406 GPS modules.
  • Has six spare analog inputs (with ADC on each) and six spare digital input/outputs to add additional sensors
  • Supports addition of wireless modules for real-time telemetry
  • Based on a 16MhZ Atmega328 processor. Total onboard processing power aprox 24 MIPS.
  • Very small: 30mm x 47mm
  • Can be powered by either the RC receiver or a separate battery
  • Four RC-in channels (plus the autopilot on/off channel) can be processed by the autopilot. Autopilot can also control four channels out.
  • LEDs for power, failsafe (on/off), status and GPS (satellite lock).
Resources:
ArduPilot requires the free Arduino IDE to edit and upload the code to the ArduPilot board.
The code is currently optimized for the Mutiplex EasyStar three-channel powered glider and FMA sensors, but can be modified for other aircraft and sensors. It uses the rudder/ailerons and elevator to maintain level flight and navigate to GPS waypoints. It supports a desktop setup utility and ground station software. It also includes a "fly-by-wire" mode that simply stabilizes RC flight. The main code is ArduPilot2.x.zip in the download section of our Google Code repository, where x is the latest version.
What you need to make a fully-functional autopilot:
Open source extras:
  • If you want to build your own board from scratch, the necessary files and component lists are here.
  • [Note: you shouldn't need this, since this code is loaded on the ArduPilot board at the factory] Latest multiplexer code (for the board's second processor, an Attiny, which runs the failsafe system) is here.
    Instructions for loading this code are here.
Recommended UAV setup:
3689303688?profile=original
Airframe option one: Hobbico SuperStar (49" wingspan, $95, shown above). This is an inexpensive, good flying high-wing trainer with ailerons. It can be hand launched in a park or take off from a runway, and replacement parts are readily available in case of a crash. If you want much better performance with this aircraft, you can upgrade it to a brushless motor, speed controller and a LiPo battery. [If you don't already have one, you'll also need a balancing charger and power supply.] Note: any stable aircraft with both ailerons (for stabilization) and rudder (for navigation) can work, so feel free to experiment with what you've got.
3689313666?profile=original
Airframe option two (recommended for ArduPilot 2.x): EasyStar (shown above). Performance can be improved with the modifications described in this post.
You'll also need:
  • A six or seven channel RC transmitter and receiver, with at least one toggle switch (ideally three-position but two-position will work, too, although you will have to mix channels to have access to both autopilot modes in the air), such as the Futaba 7C.
  • Some servos (at least three for ArduPilot 1.0; at least two for ArduPilot 2.x) and at least three female-to-female servo cables to connect the RC receiver to ArduPilot.
Cool optional extras for your UAV:
    The code is not difficult to modify if you take the time to go through it and build an understanding of what it is doing, and you can read a reference resource for the C language.
    A couple things to note. The 4th servo output is currently not implemented, and doing so will involve a minor hardware modification and some programming involving interupts, which is not beginner level programming.
    Also, on the question of flight at 75 degrees nose up - as you approach 90 degrees use of separate aileron and rudder input becomes important for stable flight. The ArduPilot code is written to use either aileron OR rudder control, not both. Changing it to use both in an independant manner will be a somewhat involved change to the program, in addition to the hurdle of implementing the 4th servo output. It can all be done, but may be beyond reach of a beginning programmer.
  • Thanks for the input so far. The vertical component would be nose up. I think I will have to research into this more, programming and electronics are not a strength for me. Any idea how difficult it is to edit the code?
  • I.A. No, the four channels "in" are normally the same 4 channels "out." Ardu can pass the signals through to the servos (you are in control) or it can assume control. Of course, you can do anything you want with any unused digital or analog pins on the CPU, such as pull a pin high or low at a waypoint. Or, if you can reduce the channels it uses to fly the aircraft (example fixed throttle, no rudder), you may use those unused channels for your own servo functions.
    In reality, you probably want to use another Arduino (of one variant or another) to control auxiliary functions and have the autopilot signal the add-on board via serial or something.
    Near vertical as in nose up or as in rising flight? I have seen Blimpduino variants go about straight up while "level." I haven't dug too far into the code, but I don't see why an ArduPilot can't go near vertical. If the code can't handle it now, I'm sure it could be written to do so. Remember that this is not an off the shelf solution for anything except possibly an EasyStar (and even then...). If it can't do what you want, you make it do what you want. This is about the best and easiest solution for the hobby market, but it isn't turnkey.
  • Question re: Ardupilot 2.3:
    In the features section about it is stated; "Four RC-in channels (plus the autopilot on/off channel) can be processed by the autopilot. Autopilot can also control four channels out."
    Does this mean the ardupilot can control 4 addition channels on top of aileron, elevator, throttle? If so can these channel functions be triggered by a specific GPS waypoint? For example at a specific gps waypoint could speed brakes be activated?
    Finally does anyone know if the Ardupilot is capable of guiding a near vertical (~75deg) flight path?
    Any help or enlightenment would be greatly appreciated.
    Thanks in advance!!
  • I downloaded ArduPilot24 from googleCode and attempted to compile it. The compile failed, after some debugging I found that there is a missing "/" in easystar.h, line 139. This causes the variable to be corrupted.
    Hope this was helpful and posted in the right place.
  • Labview compiles as you write the code, that is one of the nice features of Labview, test as you write. As long as the application is on the computer you have Labview installed on you can run your app any time without the application builder. The application builder is only needed if you want to distribute executables to folks that do not have Labview installed.
    Greg
    Earl,
    Can you elaborate? If you cannot compile an exe how do you use it? Can the runtime engine compile from the source?
  • Yea, it's a great program for $80. I bought it just for the ground station and it was worth it.I learned a little bit of labview in the process. It is useful for other projects.
    The one drawback for me is the student edition does not compile an exe program from the source. That add on is $900 and I cant justify it.
    Earl
    I have been wanting to have access to the source code for the laptop groundstation ArduPilot code, but I have no ancillary access to Labview, and I certainly won't be paying for the full version. I see that Labview 20009 Student edition is available for about $80, and from this page - http://digital.ni.com/public.nsf/allkb/769B44838BAE129D862572E30067...
    it looks like it does most everything the full version does. However, not knowing Labview I am unsure if the things it does not have (Application Builder, Source Code Control Tools, Productivity Toolkits) would limit what I would likely do with it.
    Anyone familiar with Labview recommend or not recommend the student edition???
    The "V2" shield is just the term people are using for the current (blue) shield that's sold in the DIYDrones store. The main difference between it and the older (red) shield is that this one does a better job of alllowing you to upload code with the GPS attached (that worked with some, but not all GPS modules before). Otherwise the two shields are functionally the same.
