  • Likewise TCIII...dribbling with anticipation!
    Also repository is and running, assuming Chris, is happy with how its done....
    If and when he clears it i will post the address,
    Mike.
  • Admin
    Just checked my account at the DIY Drones Store and found that my Ardupilot Mega IMU has shipped! I should have it in my hands by this Saturday!
    TCIII
  • Ah takes me back to my days running Tyco/quad pick-n-place machines.
    Gary, yes, Jordi no longer has to build boards in the dining room!
  • Yes this would be very useful thanks Chris and the doc
    Nice one guys, has Jordi got any more room to live in his new house now??
  • No problem......will report back this afternoon, with how and where.
    Possibly all you have to do it create a link or wrap it into here for continuaty.
    Mike.
    For starters, just a place to put the following excerpts from the config file (tweaked for a given airframe), description/instructions for that airframe, comments and maybe a voting mechanism, I think:
    //NAVIGATION: PARAMETERS
    //Note: Some Gains are now variables
    //4-1
    #define HEAD_MAX 4500 // The maximum commanded bank angle (left and right) degrees*100
    //4-2
    #define PITCH_MAX 1000 // The maximum commanded pitch up angle degrees*100
    //4-3
    #define PITCH_MIN -1500 // The maximum commanded pitch down angle degrees*100
    //4-4
    #define XTRACK_GAIN 00 // amount to compensate for crosstrack (degrees/100 per meter)
    //4-5
    #define XTRACK_ENTRY_ANGLE 3000 // Max angle used to correct for track following degrees*100
    //4-5
    #define LOITER_RADIUS 40 // radius in meters of a Loiter
    //4-6
    #define REMEMBER_LAST_WAYPOINT_MODE 0 // If set 1 = will remember the last waypoint even if you restart the autopilot.
    // 0 = Will start from WP 1 (not 0) every time you switch into AUTO mode.
    //4-7
    #define WP_ALTITUDE_RADIUS 10 // (meters) accuracy needed to find our waypoint in meters [not implemented]
    //4-8
    #define ABSOLUTE_WAYPOINTS 1 // 0 = relative, 1 = absolute [not yet implemented in config utility; must use waypoint writer in test suite to configure]
    //4-9
    #define AP_STICK_MIXING 1 // 0 = no mix, 1 = mix. Mixing lets you "nudge" when in auto modes
    //ATTITUDE: ROLL GAINS [Start with changes of no more than 25% at a time]
    //5-1 IMPORTANT!! Servo Gain values will be 100 times less than equivalent gains for ArduPilot 2.5
    #define SERVO_ROLL_P .006 // Primary value to tune - overall proportional term determines how much rudder/aileron you use to turn
    //5-2
    #define SERVO_ROLL_I .0 // roll PID integrator gain (value should generally be low)
    //5-3
    #define SERVO_ROLL_D 0.0 // roll PID derivative gain (for advanced users - should be zero for most airframes)
    //5-4
    #define SERVO_ROLL_INTEGRATOR_MAX 500 //Maximium integrator value in degrees * 100
    //5-5
    #define ROLL_SLEW_LIMIT 0 // Use to limit slew rate of roll servo. If zero then slew rate is not limited
    // Value is degree per second limit
    //ATTITUDE: PITCH GAINS [Start with changes of no more than 25% at a time]
    //6-1 IMPORTANT!! Servo Gain values will be 100 times less than equivalent gains for ArduPilot 2.5
    #define SERVO_PITCH_P .006 // Pitch Proportional gain
    //6-2
    #define SERVO_PITCH_I .0 // Pitch integrator gain (value should generally be low)
    //6-3
    #define SERVO_PITCH_D 0.0 // Pitch derivative gain (for advanced users - should be zero for most airframes)
    //6-4
    #define SERVO_PITCH_INTEGRATOR_MAX 500 //Maximum integrator value in degrees * 100
    //6-5
    #define PITCH_COMP .10 //Pitch compensation vs. Roll bank angle.
    // NOTE!! The implementation of pitch compensation has been changed.
    // The optimal value for your airframe will likely differ between 2.5 and 2.6
    //NAV: ROLL GAINS [Start with changes of no more than 25% at a time]
    //7-1
    #define NAV_ROLL_P .6 // Primary value to tune - overall proportional term determines how aggressively we bank to change heading
    //7-2
    #define NAV_ROLL_I .0 // roll PID integrator gain (value should generally be low)
    //7-3
    #define NAV_ROLL_D 0.0 // roll PID derivative gain (for advanced users - should be zero for most airframes)
    //7-4
    #define NAV_ROLL_INTEGRATOR_MAX 500 //Maximium integrator value in degrees * 100
    //NAV: PITCH GAINS [Start with changes of no more than 25% at a time]
    //8-1
    #define NAV_PITCH_P .65 // Overall proportional term determines how aggressively we change pitch to maintain airspeed
    //8-2
    #define NAV_PITCH_I .0 // PID integrator gain (value should generally be low)
    //8-3
    #define NAV_PITCH_D 0.0 // PID derivative gain (for advanced users - should be zero for most airframes)
    //8-4
    #define NAV_PITCH_INTEGRATOR_MAX 500 //Maximium integrator value in degrees * 100
    //ENERGY HEIGHT: THROTTLE OUTPUT GAINS [Start with changes of no more than 25% at a time]
    //9-1
    #define THROTTLE_P .32 //Proportional
    //9-2
    #define THROTTLE_I .04 //Integrator
    //9-3
    #define THROTTLE_D 0.0 //Derivative
    //9-4
    #define THROTTLE_INTEGRATOR_MAX 20 // (0-125) 70=50% Integrator limit.
    //9-5
    #define THROTTLE_SLEW_LIMIT 0 // Use to limit slew rate of throttle output. If zero then slew rate is not limited
    // Value is throttle value (0-125) per second limit
    //FLY BY WIRE AIRSPEED: THROTTLE OUTPUT GAINS
    //10-1
    #define THROTTLE_FBW_P .32 //Proportional
    //10-2
    #define THROTTLE_FBW_I .04 //Integrator
    //10-3
    #define THROTTLE_FBW_D 0.0 //Derivative
    //10-4
    #define THROTTLE_FBW_INTEGRATOR_MAX 20 // (0-125) 70=50% Integrator limit.
  • Oh,for the record, the P&P machine is the puppies....sorry forgot to mention...(my bad)
    Mike.
  • Tell me how you want it, how you want access to it, who is in control of it, and how you want it to look?
    host a number of servers of my own, and happy to create a repository for DIYd users...
    Let me know Chris...it could be up and running by tonight...
    regards,
    Mike.
