  • What ESC to use with this unit? Will it come with one?
  • @Rustom It looks really nice thruster:-)
    I have one question on this thruster for the allowance of depth in the water.
  • Hey Gary,
    We replaced the bearings with high-performance plastic bushings. The material we used is designed specifically for underwater applications and it works great. The stator and rotor are coated with a protective epoxy coating that is impregnated into the winding under vacuum so there are no trapped air bubbles.
    We won the "Proto Labs Cool Idea! Award" a few months ago (http://www.protolabs.com/cool-idea/previous-awards#9878) so we've got injection molded parts now. The image you posted is 3d printed. It looks like this now:
    3701799987?profile=original
    It's got about 5 pounds of thrust and it's pretty compact with a 3" prop diameter.
    Stay tuned! They'll be available pretty soon.
    -Rusty
  • Hi Rusty,
    That pretty much looks like exactly what I am looking for.
    I know there are a few pro units and customs built into submersibles that work like this but they are totally out of my price league.
    Out of curiosity I would like to know what you are doing for the exposed bearings if that isn't a secret, but you can probably sign me up for a pair of these.
    3701800065?profile=original
    Great Job.
    Best Regards,
    Gary
  • Gary,
    We've been working on a thruster for applications exactly like this. In fact, we've been building a few APM powered vehicles for the water. (http://hackaday.io/project/1677-SolarSurfer)
    If you're interested, check them out at bluerobotics.com. We're launching a Kickstarter campaign pretty soon. The thrusters will be much cheaper than anything on the market right now (except using a brushless motor directly), and they are built for the ocean.
    -Rusty
  • A bit pricey, but I've been looking for a decent brushless trolling motor that could be converted and the Protuar (from Australia is available in Canada) for $650.00: http://www.aquamarineboat.com/index.php?mode=prod&id=219
    Couldn't find a US distributor though.
    I thought about running open frame brushless with ceramic or silicon carbide bearings, but one problem seen by others in the open ROV project is that clearance is so small and grit so prevalent that both the bearings and the stator clearance is rapidly compromised.
    Low KV large diameter Multicopter motors should work and am currently thinking about sealing the motor completely and providing magnetic coupling to prop / thruster.
    If you wanted to go seriously deep you could immerse motor in Silicone fluid (cool better anyway).
    Optimally, this should be designed with the coils in a center completely encapsulated unit surrounded with some clearance by the magnetic rotor with the prop blades attached to the outside of the rotor.
    Bearings / bushings are still a problem, but there are a number of submersible approaches.
    Aquamarine Boats - Company News
    Aquamarine inflatable Boats - Company News provides the user with up-to-the-date company news stories,web site updates and company press releases.
  • 100KM
    Thomas,
    Interesting projects.  Are those pontoons about 1m in length?  I would think the Villain will have puny props driven with high kv motors.  They may not be very effective driving that large of a "hull".  Depending on your mission, you probably want bigger, slower turning props.  I used to be into FE boats before planes/uav's and have often thought about what I could do with APM on the water.  Keep us posted.
  • Admin
    @Gary,
    Being a System Engineer I look for product to integrate into any project that I am working on at the moment instead of trying to build my own.
    In this case, the pontoons are a Great Planes product and are designed to replace the landing gear on planes of around a .60 engine size. They can support around 10 pounds.
    I am planning on putting propulsion gear from a Traxxas Villain EX R/C racing boat in each pontoon and use a Pixhawk to provide skid steering navigation.
    The Pixhawk will be mounted on a plate attached to the wire frame between the pontoons and will be protected by a waterproof cover.
    I am also working on a Traxxas Villain EX R/C racing boat to use in autonomous boat competitions though they are still kind of rare:-)
    TCIII ArduRover2 Developer
  • Looks great Tom,
    Did you fabricate those Pontoons yourself?
    TIG welded Aluminum?
    Going to do a Tilapia Census in the Canals? (Didn't have Tilapia when I lived there).
    Regarding the Ocean going Kayak, looks really good, but Black seems to me to be a singularly bad choice for color, at night or on dark days it will make it as hard as possible to see and avoid.
    International Orange would be good.
    Best,
    Gary
  • That would be great here... Thinking the same in a paddleboard
