Autonomous ball drone bounces off anything
3689603884?profile=original
From Motherboard:
An article in the Journal of Field Robotics describes the first tests of the GimBall, a drone that appears pretty indestructable, even during flight. The drone is designed to literally collide with objects and continue moving. To make this possible, the team trades obstacle-detecting sensors for a spherical rigid frame that can roll on and around obstacles while in flight, protect against debris, and propel it along the ground. It looks like this:
Image: Journal of Field Robotics
The drone was also tested in a series of pre-programmed autonomous flights in a fairly thick forest. The algorithm ordered GimBall to fly up to an altitude of a meter, then to head north until the "end of [the] experimental area." As you can see in the video below , its a terrifyingly efficient bushwacker, even with its roll-cage being made with polygons that are too wide to protect against thin branches.
3689604068?profile=original
The engineers originally debuted the tech last year, but have a few plans for GimBall V2: They plan to tighten up the roll cage's openings, adding thin force sensors to the cage itself, and further optimize the mathematical collision program to enable GimBall to efficiently drive on the ground or ride along an uneven surface. All of these are changes are inching towards a drone that can stay in the air, no matter what.
It's a design that's already making its way into commercial drones, on a rudimentary level, at least. Parrot's new mini drone features a roll cage—the drone can travel on the ground and bump off walls with no problem. It's not nearly as sophisticated, however, as the GimBall, so let's take a look at its inner workings.
The team, led by Adrien Briod and Przemyslaw Kornatowski, of Switzerland's Ecole Polytechnique Federale de Lausanne, had to design a frame with geometry that could keep the drone stable, airborne, and controllable when ricocheting or powering through something.
Briod's team uses an internal frame that's made from a type of free-rotating camera-stand, called a Gimbal System—hence the name. On the inside of the drone's Gimbal System's there's a propeller, stabilization system, and camera, and on the outside, there's a roll cage. The whole thing works because, when it hits something, the outside frame rotates and absorbs shock, while only minimally affecting the orientation of its propeller. When a collision happens, the propeller only rocks enough to slightly impact its flight path.
  • Ahah, I'm sure GimBall would enjoy meeting its Japanese counter part.
    One thing we realized however is that adding a fixed protective cage cannot prevent a crash in many situations, because of the torque that may put the platform in an unstable orientation during a contact. Also, the fixed cage adds inertia that slows down the stabilization significantly.
    We solve all these problems (and more) with a gimbal system !
    Nice looking light frame, light and easy to repair. If we compare this and japanese ball drone, is gimbal system only main difference between those? Both gimballed and fixed seems to recover easily from collisions. Ok gimballed allows you to "drive" along walls without stopping which is nice addon.
    I wonder which type is mode efficient. GimBall has coaxial motors but light frame, Japanese has single motor but heavier frame. Would be really interesting to see them flying side by side :)
    Japanese:
    GimBall:
  • We're turning this technology into a commercial product: www.flyability.com. Don't hesitate to contact us or post here for more info or suggestions ;)
