Autopilot control in Xplane
3689374553?profile=original
Hello... I have small problem with autopilot.I try to make simulation on xplane9.Before I activate autopilot everything is good.But when autopilot is on ,plane flies strait forward and climbing slowly,instead of
flying to waypoints.Ardusimulator working properly.GPS and plane IMU datas
updating well.I couldn’t figured out what is the problem.Could you help me
plese???
As you can see from image.When I activate ardupilot , it adjust plane IMU roll=0 and Pitch=between
1.5 to 4.İt doesnt control heading.it gets fix when autopilot on condition.
  • ok... I fixed the prooblem.As chris says i did not look at flight mode.Now its perform flawlessly.I m soo happy now.Sorry about wasting your time with this simple problem.I m new at this electronic stuff. I will uplad real flight video as soon as posible :))
    Also the reason for the climb is the plane was not trimed for level flight at full throttle.
    You never went into Auto mode. As you can see, you were just in FBW A. Did you go through the setup process to assign different modes to your toggle switch, as instructed in the manual?
