    Try scicoslab -debug and let me know the output.
  • I have done as you said. It starts scicoslab in a new window for 1 second and then the scicoslab shows "mode(-1)" then it terminates !!!!
    May be there is an error in oooark compilation ? or What do think ?
    Ok seems like you have everything working but are just calling it wrong.
    start the terminal
    in the terminal:
    cd "your path to oooark"/oooark
    ./autobuild.sh
    cd scicoslab   <-- chanes you into the scicoslab directory where the scilab.ini file is to load the oooark blocks
    scicoslab  <-- calls the scicoslab command to start scicoslab in your current directory
    Now scicoslab will start up and launch the demo automatically.
  • By the way, I installed the version  ScicosLab-4.4b7, exactly as you said. So I think this is not the source of error.
  • I have compiled it successfully at last. Thanks God.
    When I wrote in the shell : exec scicoslab   the shell exits !! Is this normal ?
    In addition , I did not found the demo you suggested (VisTest.cos ) in  the path File->Open->demos->VisTest.cos, but I found it in demos folder in /oooark/scicoslab/demos, also when I clicked it to run, scicoslab gave me 4 errors;
    The first :
    Problem loading car
    undefined variable : car
    Use Activate_Scilab_Window and redefine it in Scilab.
    The rest of errors are the same, but instead of "car", it wrote plane, jet , quad.
    I think that there is no connection between scicos and oooark, right ? How can solve this problem?
    I made it require only osg 2.0.0 or greater so it should work for you now.
    cd ~/oooark
    git pull
    ./autobuild.sh
  • I have done as you said and I downloaded gcc, visualisation, math, flightgear comm . But it seems that some thing is not going well regarding the visualisation (open scene graph version 2.8.3 required, while the newest version available for ubuntu -as I know - is 2.8.1 !!!):
    mostafa@ubuntu:~$ cd oooark
    mostafa@ubuntu:~/oooark$ ./autobuild.sh
    -- The C compiler identification is GNU
    -- The CXX compiler identification is GNU
    -- Check for working C compiler: /usr/bin/gcc
    -- Check for working C compiler: /usr/bin/gcc -- works
    -- Detecting C compiler ABI info
    -- Detecting C compiler ABI info - done
    -- Check for working CXX compiler: /usr/bin/c++
    -- Check for working CXX compiler: /usr/bin/c++ -- works
    -- Detecting CXX compiler ABI info
    -- Detecting CXX compiler ABI info - done
    -- The Fortran compiler identification is GNU
    -- Check for working Fortran compiler: /usr/bin/f95
    -- Check for working Fortran compiler: /usr/bin/f95 -- works
    -- Checking whether /usr/bin/f95 supports Fortran 90
    -- Checking whether /usr/bin/f95 supports Fortran 90 -- yes
    -- Looking for Q_WS_X11
    -- Looking for Q_WS_X11 - found
    -- Looking for Q_WS_WIN
    -- Looking for Q_WS_WIN - not found.
    -- Looking for Q_WS_QWS
    -- Looking for Q_WS_QWS - not found.
    -- Looking for Q_WS_MAC
    -- Looking for Q_WS_MAC - not found.
    -- Found Qt-Version 4.5.2
    CMake Error at /usr/share/cmake-2.6/Modules/FindBoost.cmake:868 (message):
      Unable to find the requested Boost libraries.
      Unable to find the Boost header files.  Please set BOOST_ROOT to the root
      directory containing Boost or BOOST_INCLUDEDIR to the directory containing
      Boost's headers.
    Call Stack (most recent call first):
      CMakeLists.txt:77 (find_package)
    -- Found osgDB: /usr/lib/libosgDB.so
    -- Found osgUtil: /usr/lib/libosgUtil.so
    -- Found osgViewer: /usr/lib/libosgViewer.so
    -- Found osg: /usr/lib/libosg.so
    -- Found OpenThreads: /usr/lib/libOpenThreads.so
    -- ERROR: Version 2.8.3 or higher of the OSG is required.  Version 2.8.1 was found.
    -- Looking for Fortran cblas_dgemm
    -- Looking for Fortran cblas_dgemm - not found
    -- Looking for Fortran sgemm
    -- Looking for Fortran sgemm - found
    -- Looking for include files CMAKE_HAVE_PTHREAD_H
    -- Looking for include files CMAKE_HAVE_PTHREAD_H - found
    -- Looking for pthread_create in pthreads
    -- Looking for pthread_create in pthreads - not found
    -- Looking for pthread_create in pthread - found
    -- Found Threads: TRUE
    -- A library with BLAS API found.
    -- Looking for Fortran cheev
    -- Looking for Fortran cheev - found
    -- A library with LAPACK API found.
    -- Found SIMGEAR
    -- Found SCICOSLAB
    -- could not find package BOOSTNUMERICBINDINGS, building from source
    -- could not find package JSBSIM, building from source
    -- could not find package MAVLINK, building from source
    -- install_name /usr/local/lib
    --     LIBRARY            BUILDING
    --     Communication        YES
    --         Mavlink        YES
    --         JSBSim        YES
    --         Simgear        YES
    --     Scicos            YES
    --     Visualization        NO
    --         OpenSceneGraph        NO
    --         QT4        YES
    --     Math            YES
    --         Lapack        YES
    --         Fortran        YES
    CMake Error: The following variables are used in this project, but they are set to NOTFOUND.
    Please set them or make sure they are set and tested correctly in the CMake files:
    Boost_INCLUDE_DIR (ADVANCED)
       used as include directory in directory /home/mostafa/oooark/src/communication
       used as include directory in directory /home/mostafa/oooark/src/math
       used as include directory in directory /home/mostafa/oooark/app/trim
    -- Configuring incomplete, errors occurred!
    make: *** No targets specified and no makefile found. Stop.
    It seems that one step remains, the only error remaining is the open scene graph error.
    Thanks for your patience
    Also I gave you the wrong git url. It is "
    git clone git://oooark.git.sf.net/gitroot/oooark/oooark"  for public access.
    Also, make sure you have scicoslab 4.4b7 installed as there is currently an issue with scicoslab 4.4 that I have yet to fix.
    It looks like you are missing gcc. So try:
    rm -rf oooark ( if you still have the old directory)
    git clone ssh://oooark.git.sf.net/gitroot/oooark/oooark
    cd oooark
    This install gcc: sudo apt-get install build-essential
    If you want visualization blocks: sudo apt-get install libopenscenegraph-dev
    If you want math blocks: sudo apt-get install liblapack-dev gfortran
    If you want flightgear comm blocks: sudo apt-get install simgear-dev
    Then I made this script to call cmake in a build directory and then call make.
    ./autobuild.sh
    Then:
    cd ./scicoslab
    exec scicoslab
    When scicoslab is running:
    scicos
    Then to run a demo:
    File->Open->demos->VisTest.cos (for example)
    Then click run on the diagram.
