My latest autopilot with new ADXRS453 gyros is ready for testing.
- Two switching power supplies (Traco Power) at 6.5V and 5V for low power dissipation
- Separated reference voltage with RLC filter for sensors
- Separated reference voltage with RLC filter for ATXMEGA's ADC reference input
- Separated power supply with RLC filter for MCU's digital side
- Two MCU's ATXMEGA128A1 @ 40Mhz (40+40 MIPS), one for AHRS and one for navigation
- ADXRS453 ultra high vibration rejection gyros, digital output (SPI)
- LIS344ALH Accelerometer
- HMC5883L 3D Compass
- MPL3115A2 I2C Precision Altimeter - internal ready calculated altitude !! - saving MCU time for other tasks
- 6 R/C inputs
- 8 PWM outputs (460Hz)
- 2 PWM outputs for servo camera stabilization
- 8 digital outputs (500mA/each) for buzzer, external LED's,payload trigger,etc
- 2 spare analogical inputs @ 12bit
- 4 general purpose I/O's (I2C, UART, PWM)
- battery voltage monitoring
- Serial COM. for GPS
- Serial COM. for XBEE
- Serial COM. @ analogical input for ultrasonic Sonar
- Four LED's for GPS,XBEE,etc.
I will start doing testings with the AP in high vibration environment - by using unbalanced propellers + motors and see how well gyros will perform. In following days, MPL3115A2 will be also delivered. Just waiting to see the altitude precision of this new IC.
Will keep you posted about testing results.
Cheers,
Sergiu
Did you try the highest oversampling setting for MPL3115? With the oversampling set at 128 I obtained a rate of ~3Hz of altitude measurements which were rather stable from sample to sample (a few centimeters). However the problem I encounter with this sensor is that it requires about 2-3 minutes of running at full speed before it actually settles on stable measurement - for the first 2-3 minutes the measurements slowly "float" up or down until they settle.
Attached is the chart from a test flight - MPL3115A2 was "warmed up" for 2 minutes before the flight. For this flight the sensor is configured for oversampling of 32 measurements for the effective rate of about 10 Hz (light blue line) which then smothed by the IIR filter with alpha=1/32. My data logger takes measurements every 10 msec while sensor data changes about every 100 msec, so on the chart you may see "flat" lines between the moments I obtain the new measurements. Dark blue line represent the "smoothed" sensor data.
Hi
This is the code I used a while ago:
Rem Absolute pressure sensor
Dim Twi_start As Byte
Dim Alt_static As Single , Alt_temp As Single , Tmp_frac As Byte
Dim Mpl_dev_id As Byte , Mpl_status As Byte , Mpl_int As Integer
Dim Mpl_alt_msb As Byte , Mpl_alt_csb As Byte , Mpl_alt_lsb As Byte
Dim Mpl_temp_msb As Byte , Mpl_temp_lsb As Byte
Dim Byte1 As Byte At Alt_static Overlay , Byte2 As Byte At Alt_static + 1 Overlay
Dim Byte3 As Byte At Alt_static + 2 Overlay , Byte4 As Byte At Alt_static + 3 Overlay
Dim Timer_static As Single , Dt_static As Single
Open "twic" For Binary As #3
Config Twi = 400000
I2cinit #3
Rem Read MPL3115A2 dev Id which should be &C4
I2cstart #3
I2cwbyte &HC0 , #3 'write addr.
I2cwbyte &H0C , #3
I2crepstart #3
I2cwbyte &HC1 , #3
I2crbyte Mpl_dev_id , Nack , #3
I2cstop #3
Print #2 , Hex(mpl_dev_id)
Rem Set to Altimeter with OSR=128
I2cstart #3
I2cwbyte &HC0 , #3
I2cwbyte &H26 , #3
I2cwbyte &HB8 , #3
I2cstop #3
Rem Enable Data Flags in PT_DATA_CFG
I2cstart #3
I2cwbyte &HC0 , #3
I2cwbyte &H13 , #3
I2cwbyte &H07 , #3
I2cstop #3
Rem Set Poling active and start device
I2cstart #3
I2cwbyte &HC0 , #3
I2cwbyte &H26 , #3
I2cwbyte &HB9 , #3
I2cstop #3
Declare Sub Altitude_static()
Timer_static = Timer_static + Dt_static ' I read sensor at every 1.3 seconds
If Timer_static >= 1.3 Then
Timer_static = 0
I2cstart #3
I2cwbyte &H01 , #3
I2crepstart #3
I2cwbyte &HC1 , #3
I2crbyte Mpl_alt_msb , Ack , #3
I2crbyte Mpl_alt_csb , Ack , #3
I2crbyte Mpl_alt_lsb , Ack , #3
I2crbyte Mpl_temp_msb , Ack , #3
I2crbyte Mpl_temp_lsb , Nack , #3
I2cstop #3
Tmp_frac = Mpl_alt_lsb
Shift Tmp_frac , Right , 4 'use bit7-4
Mpl_int = Makeint(mpl_alt_csb , Mpl_alt_msb)
Alt_static = Tmp_frac / 10
Alt_static = Alt_static + Mpl_int
Tmp_frac = Mpl_temp_lsb
Alt_temp = Tmp_frac / 10
Alt_temp = Alt_temp + Mpl_temp_msb
'Print #2 , Alt_static ; " " ; Alt_temp
End If
Reset Watchdog
End Sub
However i came to the conclusion that no accuracy can be obtained from this digital absolute sensors. The result is jumping +/- tens of centimeters.
The only reliable way to use in multicopters is using of something like MP3h6115A and some Sallen Key op-amp filter.
Sergiu
Eugenijus
So far I am one man show. So it takes longer time to finish one project than team working. On the other hand it have only my mistakes...For more info on two MCU's AP see my other post :
http://diydrones.com/profiles/blogs/xmega-ap-and-esc
Sergiu
Euginijus,
At the beginning I made Ap's with even 4 MCU's. All of them ATmega. One was doing R/C reading, another GPS and compass,etc. I did a big step forward when XMEGA came out. With it, I made my first AP with one MCU only. It was possible not because of higher MIPS but because of DMA. Later, keeping navigation (R/C input, PWM output, GPS, Sonar) in one MCU and AHRS ( gyro,accelerometer,compass) in another MCU, given me more processing power and more MCU peripherals. However is nothing about " do not keep all eggs in same basket " because any of the MCU will fail, the copter will crush. Having only one MCU with enough MIPS and DMA (like STM32) it is also OK. You don't need to bother anymore about MCU's data exchange.
Sergiu
Right now I'm working on the code for SPI comm. with gyros.
I use (for many years ) Bascom AVR compiler.
Yeah... there go the nice and expensive gyros from your other post!
Their "neighborparts" are also great, including those low heat switching power suppliers.
Looking forward to know about the funniest tricky part: the code. =)
