Backup system for BEC
So after much reading and research into the whole "backup" BEC saga. I think I've found a solution!
My first idea was just to run a 5.5v backup lipo in parallel with the 5v UBEC output.
This idea has been vitoed by most. Too many unknowns apparently.
The other was to parallel all the BECs up, but this would cause harmonics due to all the square wave interaction.
So I figured we cant mix power supplies. Other than using a microproccessor controlled mosfet to switch
power supplies when and if the bec dies.
We use a relay :) Bear with me.
The main power supply powers the relay. With the relay closed (NO) power is routed via the bec to the apm.
If the bec fails, the power to the relay fails and is switched to the auxillary power supply (battery or another bec)
This completely seperates the two power sources.
Will the relay be able to switch fast enough to the auxillary power source without the APM losing power?
If not, im sure a power capacitor will keep the APM alive long enough for the bi-pass surgery to take effect?
Above is a recording of the ciruit just in case my explaining skills are dodgy :)
  • My bad, I forgot about the minimum operating voltage.  The OKI-78SR regulators are pretty bullet proof and can be or'ed (will startup with a bias on the output).  How about just using two OKI-78SR regulators (one from each battery) and wiring the outputs together.  No surface mount, extremely efficient and reliable.
    As for noise, the OKI-78SR regulators produce about 20mv of switching noise on the output which is going to be on-par with a 7805 running on a battery with other loads (78db of power supply supply rejection).  The 20mv ripple will be further reduced by the filtering on the APM.
    I have run a couple of different commercial APMs and several in-house boards with the OKI switching regulator and have not experienced any noise issues with analog or digital gyros or magnetometers (need to be kept away from the regulator, it is shielded but there is enough magnetic leakage to affect a magnetometer).
  • Alrighty then how about a 5.5v NIMH battery with a diode to stop the bec from charging it?
  • That could work, but I question the harmonics, as I've also read you can't do that.
    The other problem is you also aren't protected from the BEC failing wide open, which is how they fail half the time. Or so I'm told.
  • @ Robert: I rate that BEC could be used on the space shuttle ;)
  • @EVERYONE: Should I just parallel up two becs and add a diode to the postive line of each bec??? :)
  • @Dean:  My idea is based on L7805 5V regulator because I read elsewhere that a linear regulator is *more* reliable than a switching regulator.  It also supposedly has less switching noise.  I'm no expert on this stuff, sounds like you are, so I'd like to hear more.
    The other reason I use an L7805 is because it was available are Circuit City off-the-shelf. ;)
    I haven't been concerned about efficiency in the least. I just flew one flight pack (12 minutes) with my heli at lunch.  The radio supply battery is still at 97%.
    Also, the reason I think the LTC4358 won't work, the spec sheet says the minimum voltage is 9V?  That's way out of range for us?
    I'm not at all interested in running servo loads through this.  This is purely to supply the APM and receiver. My understanding is you absolutely CANNOT run the APM at 6V. So the requirement is about 0.2A, 5.0V and as little noise as possible.
    We could/should make a second system operating at 6V and higher amps for the servos, with noise being less of an issue.
    @Gustav & John:  I'm not sure if the the APM will run properly at 4.8V.  So running a 5V regulator through diodes might not work.  I also would rather not run it at 5.4V, because that is starting to push it.  I would like to get a power supply that supplies exactly 5.0V, with as little noise as possible.
    Joao, good point.  Another reason why the relay just will not work.  I believe 5.5V is too much for the APM.
    Another aspect of all this that has not been considered is overvoltage.  Sometimes switching supplies fail wide open.  That's bad too.  So we also need overvoltage protection.
    How about this for a spec for our "Ultimate BEC":
    1)Dual battery input (options, can use just one if desired).  These runs through an automatic switchover system to prevent a short in one battery from taking out the other.  This could absolutely be a simple diode system.  Voltage drop is irrelevant.
    2)Servo supply rail, dual 6V, rated at 10A, switching power supplies running through automatic switchover system.  Dual outputs to run two wires to servo supply rail for redundancy.  It's possible this could be two 5A supplies which can supply in parallel to meet 10A loads which would only be rare occurances.
    3)APM/Radio supply rail, 5.0V, 1A max (even 0.5A is plenty).  Linear or switching, whichever has the lowest noise.  Two regulators, automatic switchover.  Two power outputs for wiring redundancy.
    4)LED display for all 6 power supplies. (two batts, two 6V regulators, two 5V regulators.  Possible option for adding pins to the board to run status input to the APM.
    5)Over-voltage cut-out on each power supply.  I have no idea how to do this, but I bet somebody makes a chip.
  • Why have I read so many posts saying its not a good idea to parallel up becs, even with diodes?
  • Gustav: Would you get a perfectly smooth dc signal from a switching regulator?
  • People, ALL electronic circuits can fail, and the more complicated, the bigger the possibility.
    Relays are out, they have a finite switching time, and using Spektrum tech, will reset/reboot the Rx.
    On my stuff:
    a: Pawnee 40, NiCad 4 cell into Rx spare port via switch, BEC into Rx via diode, throttle port.
    b: Twin Otter, the same, except two BEC's via diodes, Y lead to Rx throttle port.
    c: Drastik 120, NiCad 4 cell via switch, LiPo and UBEC via switch, no diodes, to Rx, spare ports.
    (This one is glow powered)
    On all my Rx's I also have a 6800uF 10V capacitor plugged into a spare port.
    Oh, this part can't be true
    There should be smooth DC out of the BEC/UBEC, if not, you have a faulty unit.
  • I dont know the electronic specifics, but I have an RVOSD gen4 that uses either 1 or two batteries (via jumper setting).
    The selection is to either use one battery to power the rvosd board, or both the primary and backup batteries; auto selected via the higher detected voltage on the batteries.
    So for example, if both batteries primary and backup are 3s same exact voltage it will use both batteries equally. But while motor is spinning (motor will draw from the main only) the osd servos and its connected systems (ie gps) will draw from the backup battery; until it gets to be a lower voltage. Or for example when motor is shutdown and voltage from main battery becomes more than backup battery, it will again draw power from the main.
    A typical seniero where this is helpful,. is a lost plane.
    Lets say we start with a low battery condition; youve mistakenly run too low on power and plane is too far away to make the return trip home.
    So starting with power to motor is killed when the BEC tries to keep the servos alive.  (this description is for planes not quads)
    The Autopilot keeps running on backup battery untill reaching the voltage of the main, then it will use both batteries until they both eventually die.
    The advantage is, this leaves telemetry (if intact and able to transmit) running so are able to track down the grounded plane from gps corrdinates obtained by the groundstation
    (ie people running to the scene, but operator patiently google earthing the last known gps and trajectories) and then hopefully from the recovery team can get a better place to be looking.
    This would be a handy feature, with apm(x)
    thereby balancing its usage accross both batteries. but motor can only draw from main.
    I believe rvosd is a member here, who could explain better the technical details.
    but its a nice way of handling dual batteries...
