Backup system for BEC
So after much reading and research into the whole "backup" BEC saga. I think I've found a solution!
My first idea was just to run a 5.5v backup lipo in parallel with the 5v UBEC output.
This idea has been vitoed by most. Too many unknowns apparently.
The other was to parallel all the BECs up, but this would cause harmonics due to all the square wave interaction.
So I figured we cant mix power supplies. Other than using a microproccessor controlled mosfet to switch
power supplies when and if the bec dies.
We use a relay :) Bear with me.
The main power supply powers the relay. With the relay closed (NO) power is routed via the bec to the apm.
If the bec fails, the power to the relay fails and is switched to the auxillary power supply (battery or another bec)
This completely seperates the two power sources.
Will the relay be able to switch fast enough to the auxillary power source without the APM losing power?
If not, im sure a power capacitor will keep the APM alive long enough for the bi-pass surgery to take effect?
Above is a recording of the ciruit just in case my explaining skills are dodgy :)
  • Hi Gareth,
    I have 4 cell nicad, or nimh in my different aircraft.
    (Older tail rotor gyro's are low voltage only)
    And 1A continuous, 8A peak Schottky diodes in the BEC lines.
    Can't remember the number, but they look like a 1N4007.
    I tease the cable coming from the BEC apart, cut the red wire, solder in the diode with cathode(stripey end) pointing to the plug, and then heat shrink the lot for neatness.
    Works for me.
  • Thanks Gustav, its difficultto get a difinitive answer around here ;)
    So should i put a 4 or 5 cell NIMH battery in parallel with my bec? And where do i put the diode?
  • I see replied rather belatedly :-(
    However,
    Alrighty then how about a 5.5v NIMH battery with a diode to stop the bec from charging it?
    Why do you NOT want the BEC/UBEC to "charge" the battery?
    At 5V, 5.5V typical output range, the current flowing into the battery is negligible, if of course it is fully charged before you switch on
    Effectively I run my BEC/UBECS through a diode, straight to the battery.
    That way, the battery can supply the current spikes demanded by servos, without any drop over a diode.
    And in those periods that there is light current draw, the BEC/UBEC can top up the battery.
    I'm no engineer, but I've been flying my planes and heli's like this for a few years now.....
  • Define perfectly smooth:-)
    It should be no more than a few 10ths of a mV, if that is what you mean.
    If you google the design of a typical switching circuit, you will notice that it boils down to a capacitor that is constantly being pulsed up to the required value.
    A good design will have ripple of no more that a few mV.
    All the square wavey stuff happens earlier in the circuit, hence the RF noise that is inherent to the design.
  • For significant load currents such as would be encountered on a servo bus, Schottky diodes are not a panacea.  Even the very best Schottky will drop about 0.4V at 5A.  Better than silicon, but still far from ideal.
    Ideal diode controllers - that include a diode ORing function - have been available for a while now and represent a vastly superior solution.  An N-channel FET is used instead of the diode, and depending on the FET you should be able to keep the voltage drop well under 100mV.
  • Yes, I'm also a fan of seperate lift, and radio system batteries.
    So with your dual OKI-78SR setup, do you have automatic switchover?
    I can see how the switching noise has been improved over time but it will take a while for the reality of that to percolate down to the users.  Pretty common in the hobby industry.
  • Switching regulators used to be much more noisy, but as switching speeds have gone up, the noise have dropped for a given inductor and output capacitor size.  Also, now that switching speeds are high enough the output cap can be a low esr ceramic which further reduces noise.
    If there are no other loads on the battery the 7805 might produce less noise, but I doubt it.  Load transients will dominate the noise and the AVR can generate substantial transients without proper filtering.
    Using two OKI-78SRs would protect against a shorted cell.  One battery is connected to each OKI with the outputs tied together.  A short or 0V on the input of the OKI-78SR will just cause it to shut down and it will not load down the other regulator in this state.
    Switching regulators almost always fail open, and sometimes fail with the output shorted to ground (highly unlikely, but possible in a standard buck configuration).  Because the regulators are under-voltage protected on the input and over-current, short circuit and over-temp protected the chances of any kind of failure is very close to zero.
    We operate tri-rotors with a custom APM on a single OKI-78SR on a separate battery that runs everything except the ESC/lift motors and have never had an incident.  Early in the game we used BECs on the ESCs and had several failures (Turnigy).
    These tri-rotors are lifting 2kg sensor packages (with several thousand dollars each) so the cost of redundant power is not an issue, it is just not a probable failure mode when using the OKI-78SR or the older Murata 78SR-5/2-C regulators.
    We also run a separate battery for everything except the ESC/lift motors for safety.  Everything can be powered up and verified before a pull pin is removed enabling the ESC power (from a safe distance) (there is also an electronic lockout for the motors controlled by the APM/radio link).
  • what about this: www.rcmodels.org/csm/becsafe.pdf
    CSM Design Consultancy Ltd
  • Found this for overvoltage protection:
    http://forum.allaboutcircuits.com/showthread.php?t=20777
  • @Gareth, still have a problem if that BEC fails wide open.
    @Dean, Yes, two OKI-78SR's from seperate batteries could work.  The only problem is if you have an internal battery short, which can happen, one batt will take out the other.  Also, it *reguires* you to run two batts.  If you have dual battery input, through diodes, to a common DC bus which then supplies the OKI-78SR's, then you can use one or two batteries, and one battery cannot take out the other.  And it's just a simple diode, right?
    20mv on the 78SR is comparable to 7805 "running other loads".  What does that mean?  If I'm just running the APM and Receiver, will it generate noise?  No servos.
    The reason I'm so concerned about noise is because we have analog sensors and the noise can really mess them up.
    I'm not saying you're wrong.  Just questioning, because I've heard linear is better.
    Any ideas of overvoltage protection?  (failing wide open).
    The spec I outlined, while it looks complicated, it sounds like it's achievable.  But I'm not sure if we have a good method to automatically switchover the two 6V supplies because it's kind of in an unusual range.
    Spec 7:  Allow the 6V supplies to capable of switching through a switch, or solder jumper.  I like to be able to switch my servos off, while allowing the APM to boot.  But, some may not want or need that, and prefer the simplicity and reliability of having them always on.  One switch for each 6V channel, placed between the power supply and the switchovers, so if the switch fails mechanically, you still have a second switch.
    Wow, getting complicated, but still doable I think.
