Budget Compact Ground Station
3689548099?profile=original
All Items - Packed Up
3689548217?profile=original
All Items - Unpacked
3689548320?profile=original
FPV DVR Ground Station - Open
3689548290?profile=original
FPV DVR Ground Station - Unpacked
3689548362?profile=original
All Items - Assembled
3689548376?profile=original
FPV DVR Ground Station - Internals
3689548398?profile=original
FPV DVR Ground Station - Display
Parts:
Andriod Nexus 7 running AndroPilot (with Travel Case)
Right Angle OTG Cable
433Mhz USB radio
Suction Mount for Nexus 7
Portable 7-inch DVD Player (with headrest mountable carry case)
DIY 5.8Ghz VRX Module (with IR Remote Control)
Hobby King SD DVR (minus case and expansion board)
Futaba FP-T8UAF
FRSky DFT 2.4Ghz Transciever
Turnigy 2650mAh LiPo
Total Cost: Next to Nothing (<$150)+Tablet($250)
This old Portable DVD Player had given up the ghost. So, after repairing (and then realising that i have zero need for a portable DVD player), i took to tearing in apart again.  Removing the unwanted CD carriage, finding suitable AV inputs and a 5VDC line on the board was relatively straight forward. I had even planned to wire in the ADC_KEY_1 and ADC_KEY_2 inputs up the the existing and very conveniently located micro-switches which are no longer required for the DVD player in order to provide UP, DOWN, LEFT, RIGHT, SELECT, MENU, PLAY, RECORD and STOP buttons for the DVR, however found it unnecessary thanks to the fact that the IR receiver for the DVR gives good reception through the small clear window located in the lid to the CD carriage. NOTE - switch on rear left hand corner of FPV unit is wired into alarm trigger circuit of DVR (however, I am yet to find a mode in which this will activate/deactivate recording)
Nice and Small, Easily Portable, Wonderfully Compact, Cost Effective - Couldn't be happier with my little beginners kit.
  • Probably didn't want to cut up the Pelican. ;)
    Would be nice if there was a case for the Ardustation with a lift-off lid.  Then you could benefit from the protection during shipping, but remove the lid to expose the GPS and display in operation.
  • Kevin - No, I haven't added anti-glare yet, but will pick one up one ebay if you think I am going to need it in the field.
    Thomas - That's a nice bit of kit! Any reason why you chose to house the ArduStation separately to your Pelican cased GCS?
  • Hi Thomas,
    Thanks for your kind comments.
    A Pelican 1520 certainly is a great deal bigger but, as you say, it is far more durable (and probably a whole lot more neat).
    I would like to be able to cart this equipment and the associated 450 sized quad on a 3 day hike (into the Wollemi National Park) at some point, where both size and weight are of particular importance.
    Unfortunately, there is not enough room left in this particular DVD player to accommodate the ArduStation Mega 1.5, so i will soon be building another GS. It will likely be in a Pelican 1120.
    Jason
