Hello,this is Haley greeting from Tersus GNSS Inc. in China.
Recently we've finished testing of BX306 GNSS RTK Board for plant protection UAV in China. Our customer choose one BX306 board as Base and two BX306 boards as Rover in UAV. They mainly test the RTL(Return to Launch) function this time, the difference of original start point and landing point is 5-10cm.
BX306 is a cost-efficient GNSS RTK board for cm-level positioning and providing accurate raw measurement output, which can be integrated with autopilots and inertial navigation units.
- Supports GPS L1/L2, GLONASS L1/L2, and BeiDou B1/B2
- Supports in-built 4GB memory, which makes data collection easy
- Up to 20Hz RTK solution and raw data output
- Supports IMU raw data output
- Pin-to-pin compatible with NovAtel OEM615
- Log/command compatible with NovAtel protocol
- Supports event mark and PPS
Later we'll have more test on our RTK and PPK board, and will update once available. Thanks.
Haley
Email: yunxia.hu@tersus-gnss.com
Webesite: https://www.tersus-gnss.com
