A staggering fact is that motors and motor driven systems account for between 43 percent and 46 percent of all global electricity consumption. Needless to say, if electric motors could be made to run more efficiently, energy consumption would fall. With research out of Rice University back in 2011 demonstrating that carbon nanotubes braided into wires could outperform copper in conducting electricity, it looked like there would soon be a new way to create those improved efficiencies.
Building on that research, a team at the Lappeenranta University of Technology (LUT) in Finland hasreplaced the copper windings used to conduct electricity in electric motors with a woven material made from threads of carbon nanotubes and achieved remarkable new efficiencies in the motors.
"If we keep the electrical machine design parameters unchanged and only replace copper with future carbon nanotube wires, it is possible to reduce the Joule losses in the windings to half of the present-day machine losses,” said Professor Juha Pyrhönen, who has led the design of the prototype at LUT, in a press release.
Copper windings have traditionally been used because they are the second best metal at conducting electricity at room temperature, and they come relatively cheap. However, despite their high conductivity, they do offer some resistance—to the point where Joule losses are often referred to as “copper losses.”
Meanwhile carbon nanotubes have conductivity far beyond the best metals and their limits of conductivity have not been found: some have been measured at 100 millisiemens/meter, compared to ultra-pure copper at 58.65 MS/m. With this kind of conductivity, carbon nanotube-based windings could result in double the conductivity of today’s copper windings, according to the Finnish researchers. And as Pyrhönen claimed, Joule losses could be cut in half with the carbon nanotube yarn.
In the prototype motor made by the Finnish team, the carbon nanotube yarns are spun and converted into an isolated tape by a Japanese-Dutch company Teijin Aramid. (The actual spinning technology was developed in collaboration with Rice University.) Since this industrial use of the carbon nanotube yarn is still at its early stages, the production capacity has not been ramped up. This will have to be addressed if the new wire is to replace the ubiquitous copper windings.
However, the performance improvements are significant enough to warrant at least an investigation into whether it can become a realistic replacement for copper wiring.
"There is a significant improvement potential in the electrical machines, but we are now facing the limits of material physics set by traditional winding materials,” said Dr. Marcin Otto, business development manager of Teijin Aramid, in the press release. “We expect that in the future, the conductivity of carbon nanotube yarns could be even three times the practical conductivity of copper in electrical machines. In addition, carbon is abundant while copper needs to be mined or recycled by heavy industrial processes."
Sounds as though there’s a company that has a firm belief in the potential of their product in this application. And with the potential to put a big dent in the 45 percent of global electricity consumption that comes from the use of electrical motors, why not be confident?
A video of the motor equipped with the carbon nanotube windings is below.
@Gary thank you for insights in this technology. Hope we will have these motors up and running in few years time. :)
Hi Greg,
I think it might be possible to build specialized high output small brushless motors using this technology.
The doubling of motor efficiency actually means you could get more continuous power out of a smaller motor.
Although doubling efficiency over current motors only gives you a small efficiency increase it cuts heat production in half meaning you could drive double the continuous watts without overheating.
So the net primary benefit is potentially considerably smaller and higher power motors with half the heat loss.
Our UAV motors could certainly benefit from that as could precision hand held tools and machine tool heads.
Presuming all things are equal of course - which of course is very unlikely.
Best Regards,
Gary
Electric machines still depend on the iron laminate plates for field shaping in the induction motor world. To be sure, the replacement of copper wire with another material will reduce the device weight.It looks like the lead photo is a three pole motor, sans the copper wiring and no armature. The depth of field makes the back end of the of motor look like a sci-fi device. Clever photo.
Our beloved brushless motors would benefit but, the wire in them is often very small anyway. A copper motor can take some abuse and still operate. How brittle would a carbon nanotube device be?
Nice post. Thanks!
-=Doug
@Gary McCray
Maybe the improvement in efficiency will be no more than few percent, but could the weight of the engine drop drastically? I've got a hunch there is a possibility to build a light weight engine.
Very interesting carbon nanotubes seem to have a lot of applications.
And in common use today, inefficient wiring losses account for a lot of energy wasted and turned into unused heat.
Good motors today can already be pretty efficient, so overall energy conversion numbers would be unlikely to improve more than a few percent.
What might be more interesting would be the capability to design higher output motors that ran cooler.
Seems to me that the real potential for energy saving is in home level photovoltaics.
PV panels are down in the dollar a watt range and a 2 to 4 k watt system combined with already commonly available electrical conservation techniques and practices could cut home energy consumption in half - more if you worked at it.
Unfortunately (green money) is the new investment potential whereby the investors fund your PV panels and then take all the value back out when you pay them for your heavily financed system.
So it becomes just another way for the 1% to profit off of the rest of us.
Still great opportunities for enterprising DIYers.
