One of the best UAV platforms if you're a decent RC pilot is the HobbyKing Skyfun. Loads of room inside, and it's easy to distribute gear in the cockpit so the center of gravity stays right. It also handles the wind really well.
I had a great day flying with it today, and tuned the APM PIDs pretty well for the frame (I turned down both pitch and roll P's a bit). Here's a sample of the RTL circle with a pretty stiff wind. Not bad!
The Skyfun config file is now posted in the manual's config repository. You can load it via the Mission Planner.
No, I upgraded the motor and prop. It's not necessary, but it is nice to have 50% more power if needed.
Chris, did you use the out-of-the-box motor ?
Looks pretty well.
Max, that's the standard 30m radius.
