Copter frame assembly
OK so i got the frame parts and assembled it all...
3689397614?profile=original
APM and power distribution board:
the flat rainbow wire (black white gray purple blue) is from the power board, it carries GND, Left, Right, Front, Back.
i just used my own wire to have greater length and flexibility. i wanted the GND too because i will power the electronics with another BEC, not from one of the 4 ESC.
3689397524?profile=original
Motors mounted:
3689397631?profile=original
In the process of tidying the ESC wiring:
3689397669?profile=original
3689397541?profile=original
GPS mounted:
3689397686?profile=original
And finally the whole thing:
3689397702?profile=original
I'm still waiting for a few parts to arrive,
especially the radios, the video TX\RX as well,
and lots of parts for the DSLR camera mount i will just start to build.
soon on the way also - 2 more motors and ESC for the upgrade to a custom HEXA frame, on which the DSLR will be mounted on.
so the next post will probably be the camera mount building,
or maybe the first flight if i get the radio sooner than expected :-)
keep following !
  • could you explain ? is it about them disconnecting ?
    indeed i plan on directly soldering the wires, but as i'm going to change from quad to Hexa, i've still kept everything.
    after i fly the quad a few times i will build the hexa frame for the heavy payload. then i'll solder everything
  • Thanks, probably, yes.
    Nice!  cant wait to order mine... soon... really soon...
    Are you going to paint the arms to know what is front facing?
  • Looks really nice! Good Job!
