I recently had an inspection that required the use of a thermal camera to inspect a solar panel field for failed units. I have numerous thermal imagers, but most too big or too bulky to be used on a multi. The tau series is impressive for its size, but it is not the most plug and play camera on the market. The other issue is there is no readily available brushless gimbal with a manual tilt option. First, we installed it on our workhorse S900, but it was hard mounted to the gimbal rails with the ability to manually tilt. That obviously became a huge pain because you could never get the camera the exact way you wanted it. We researched many different posts and setups, but none were going to work for the exact way we wanted it to. After lots of trial and error, we have finally got a solid unit on our hands. We have steady, jello free video installed on a light, nimble and quick to deploy phantom 2. The phantom 2 is a good platform to install it on, as the Flir Tau 2 weighs only 5 more grams than a Gopro, and is extremely reliable. The results are pretty stunning, and its a pretty simple install once you know the pitfalls of installing a tau 2 on the phantom, and what you can do to correct it. Here is the list of the parts needed to have a complete, RTF thermal imaging phantom.
- Phantom 2 Flir Tau2 Thermal UAV
- DJI Phantom 2
- DJI 2.4ghz Datalink (Waypoints)
- DJI AVL58 Video Downlink
- DJI Mini IOSD
- DJI FPV HUB
- Flir Tau2 Thermal Camera 336 (13mm Lens)
- Flir Tau2 VPC Module
- Beholder Lite 2 Axis Brushless Gimbal
- Right Angle MCX Cable
- Right Angle MINI USB to USB Male
- 12-26 Volt to 5 Volt Regulator
We went with the 336 model with a 13mm lens. For the price, the 336 is the best option. If you are on a tight budget, the 168 model is ok, but the small price increase relative to quality for the 336 is major. The 640 is an amazing camera, but at more than double the price of the 336, we decided it wasn't necessary as of now.
The installation is pretty simple, but some minor soldering is required. The beholder lite gimbal is almost a perfect fit, and the stock gopro gimbal settings are pretty close. We did need to order some custom right angle cables, as the way the Tau 2 is mounted on the gimbal leaves very little room for straight plugs. You also need to convert the phantom 2's 12 volts to 5 volts to power the Tau 2, which is relatively easy to do with a car usb charge adapter.
Below is some up-close images of the install, and how everything is laid out. We also actively use the 2.4ghz datalink for waypoints, especially when performing inspections. We also did a quick demo video showing the recording quality of the camera, along with the gimbal performance.
You can also view details, step by step how-to and tips and tricks for the installation at http://www.nue-av.com/#!DJI-Phantom-...C-629BBF0BC19E
Here is some images of the final installation and how it is physically mounted to the phantom. If you have any questions, feel free to message me here or through our website, www.nue-av.com
@Patrick,
Thanks for sharing the info on the gimbal. Seeing someone give the thermal camera a try is interesting to see.
Some info I've found about FLIR (and other) thermal cameras:
I was also hoping to hear from someone who had some more experience with the tau lineup. I have gotten decent results, but there is so many camera options and i am not sure where to start.
I hear ya, but its no different than our rigs that have a gh4 or a 5diii on them. It could sit a little higher, but in the end its a flying camera and its a risk no matter what.
Not sure if I would expose $4000 under the DJI in open with no protection ...
Thanks, I have been fooling around with the GUI and changing the color palette. White hot probably delivers the best results, but I was trying black hot to see how well it worked. I still haven't gotten the gains figured out, as when I have a large temperature range I get a clear hot image and washed out background. I was thinking of some sort of wireless usb device with a split signal into the camera so i can change settings in the GUI while its operating.
@criro1999,
Most of the FLIR systems that I have used provide an option to use either black or white for objects with a temperature above the background temperature.
TCIII AVD
Nice video. But I was expected your body image (min 2:15) to be mostly white (heat) instead of black (cold).
