Today I'm proud to introduce you Drone Configurator.
I designed this tool to help people choose their drone parts by :
- Simulating their configuration and giving them easy to understand indicators like flight time, thrust to weight ratio, ...
- Comparing the prices of the parts from various stores
Drone-Configurator is an alternative to ecalc as it can simulate the drone behavior but it works a different way.
Instead of basing our simulation on motor specifications, we choose to use real life benchmarks to be as close as possible to the reality.
Our tool is easy to use as you just have to select the parts you need from our database and check the results, no need to understand very technical data.
We already reference lots of parts to cover most of the users needs but everybody is free to propose new parts so we hope the databse will grow fast. Please ask us the parts you need :-)
Drone Configurator is already available in English, French and Deutsch, we are looking for volunteers to help us translate it in other languages, contact me if you want to make it available in your laguage.
I hope you'll find Drone Configurator usefull, I put all my love on it :-)
As I told you, this is just the begining and we are already working on lots of new features to make your life easier...
Fell free to share it !
Thanks,
Gauthier
www.drone-configurator.com
This website helped me a lot back in 2017 when i was completing my BE final year project where we had assembled a drone from components and not from a kit.
Without this simulator i wouldn't have been able to get the specs right, that is why i am asking the reason.
Yes !!!!
Thank you Angelo, this should be ok now :)
Hi Gotleg, there are a few mistakes in the first page. Please make the following changes:
1 - Escolhar seus componentes Escolher seus componentes
Drone Configurator é uma ferramenta desenhada para ajudar você a escolher as melhores partes e optimizar a configuração do drone Drone Configurator é uma ferramenta desenhada para lhe ajudar a escolher os melhores componentes e otimizar a configuração do drone
Simulação de caracteristicas de vôo é baseado em testes de impulso real e é muito preciso. A simulação das características de vôo é baseada em testes de impulso real e é muito precisa.
Nós também referenciar as melhores lojas on-line que vende peças de aviões não tripulados e verificar automaticamente os seus preços. Você vai definitivamente encontrar os melhores preços para suas do drone. Nós também relacionamos as melhores lojas on-line que vendem peças de aviões não tripulados e verificamos automaticamente os seus preços. Você, definitivamente, vai encontrar os melhores preços para seu drone.
Thank you
Angelo
I sent you an friend request Long Hoang Pham
Many thanks Angelo, Portuguese is now online.
I missed a few translations and I tried to fill the blanks with google translate. So forgive me if there are a few mistakes and please tell me and I'll correct this :)
Hi Gotleg, portuguese version is ready
Great, I'll contact you.
Hi Chris, I just sent you a message :)
Sorry Frederico no plane planed for the moment :/
Gary, I just added 330 450 and 550 frames from HK and 1 from Hoverthings
1
2
3
4
of 4 Next
