Easy to Build Ground Station
I've been tuning the GPS portion of my ArduPilot / Magpie airframe combination, and put together this flight data recorder to save the results of the flights without having to take a laptop out to the field.The data recorder consists of a Spark Fun Data Recorder, an XBee radio modem, and a battery. The Data Recorder takes a serial stream at 9600 baud, and records it to a SD data card as a text file.The Spark Fun card takes un-regulated power in (my 6v battery), regulates it, an provides the regulated 3.2v power required for the XBee. (very simple) Just 3 wires between the XBee and the Data Recorder, V+, Gnd, and DataOut (XBee->Recorder)
I used a 4 cell battery case from Radio Shack for power - it sits on the back of a bread board used to hold everything together. Very easy. Thanks Spark Fun for making such amazing little products.The aircraft has a XBee Pro 900 modem sending out 1 line of flight data every 300 ms. I capture it with my portable download link to an SD data card that I copy to my computer at home after the flight. The Spark Fun Data Recorder saves the data as a simple text file, that I post-process into a KML file for Google Earth.|-- AP Mode:1,GPS:0,Mir:189,CH1:-2,CH2:-1,IMU:321.74,CMG:306,GHD:301.77,CRS:319.61,***|-1 LAT:36956188,LON:-122063904,ASL:34.76,ALT:34,ALH:29,***|-2 WPN:2,BER:257,DST:54,CRS:317.06,SPD:23.57,CRT:0.30,WPa:125,***|-3 ASP:0,RLL:-20,PCH:-5,THH:30,rSv:7,pSv:10,rSp:-31,pSp:5,tSp:85,***|-4 GYRO:4,Rate:428,vRef:513,Bias:-89,***|-- AP Mode:1,GPS:0,Mir:189,CH1:1,CH2:0,IMU:318.86,CMG:305,GHD:300.63,CRS:310.88,***|-1 LAT:36956340,LON:-122064112,ASL:35.76,ALT:35,ALH:29,***|-2 WPN:2,BER:230,DST:45,CRS:305.32,SPD:24.04,CRT:0.00,WPa:125,***|-3 ASP:0,RLL:-44,PCH:-7,THH:30,rSv:10,pSv:11,rSp:-40,pSp:5,tSp:85,***|-4 GYRO:54,Rate:478,vRef:513,Bias:-89,***|-- AP Mode:1,GPS:0,Mir:192,CH1:0,CH2:-1,IMU:310.09,CMG:279,GHD:278.19,CRS:297.76,***|-1 LAT:36956444,LON:-122064368,ASL:36.46,ALT:36,ALH:29,***|-2 WPN:2,BER:196,DST:42,CRS:291.87,SPD:26.01,CRT:0.40,WPa:125,***|-3 ASP:0,RLL:-44,PCH:0,THH:30,rSv:11,pSv:2,rSp:-36,pSp:5,tSp:85,***|-4 GYRO:82,Rate:507,vRef:514,Bias:-89,***|-- AP Mode:1,GPS:0,Mir:192,CH1:0,CH2:0,IMU:297.90,CMG:257,GHD:259.03,CRS:284.54,***|-1 LAT:36956468,LON:-122064512,ASL:36.96,ALT:36,ALH:29,***|-2 WPN:2,BER:164,DST:45,CRS:280.27,SPD:24.76,CRT:0.20,WPa:125,***|-3 ASP:0,RLL:-45,PCH:-10,THH:30,rSv:8,pSv:13,rSp:-45,pSp:5,tSp:85,***|-4 GYRO:9,Rate:433,vRef:513,Bias:-89,***|-- AP Mode:1,GPS:0,Mir:192,CH1:0,CH2:0,IMU:285.74,CMG:239,GHD:238.06,CRS:275.35,***|-1 LAT:36956460,LON:-122064768,ASL:37.16,ALT:37,ALH:29,***|-2 WPN:2,BER:137,DST:46,CRS:264.31,SPD:18.75,CRT:0.70,WPa:125,***|-3 ASP:0,RLL:-37,PCH:-8,THH:30,rSv:10,pSv:12,rSp:-34,pSp:5,tSp:85,***|-4 GYRO:46,Rate:471,vRef:514,Bias:-89,***// ---------------I put what-ever I want in the print_data() function of ArduPilot, and it gets copied to the output stream.After the flight, I post-process the data file into a KML for Google Earth, so I can evaluate the results of the latest code changes.
    Pete's going to be joining our groundstation development team, so I'm sure he'll be able to share design ideas there.
