T3
3689528575?profile=originalThis is a screenshot from Ecosynth's brand new 500 by 500 meter photo acquisition method, taken at Patapsco State Park!
3689528394?profile=originalThis is Wolfgang: our newest octocopter. It flew the 500 by 500 meter mission. Wolfgang is our biggest and heaviest copter, it can carry four lipo batteries plus its payload. It can stay aloft for 30 minutes of safe flying time. The camera is the new Ecosynth standard, the Canon Powershot ELPH 520. The camera is mounted in a card case for protection and ease of attachment to the copter; it points straight down to collect photos for aerial mapping.
Wolfgang uses the frame, legs, motors, and propellers of a Mikrokopter Miko XL.  However the brain is an APM 2.5, and the ESC's are jDrones 30 amp (those Mikrokopter ESC boards are too finicky and fragile.)  The electronics are covered by a tupperware container (not the most glamorous, but it is sturdy and gets the job done.)  It carries four Venom 5000mAh 4-cell lipos.  Control is the Spektrum seven channel.  One Garmin Astro dog tracker is attached for locating the copter in an emergency situation.
3689528588?profile=originalWolfgang's planned route in Mission Planner (created by Michael Oborne). The flight path is actually 550 by 550 meters, so that the 500 by 500 meter collection area is surrounded by 25 meters of buffer area on all sides. The tracks are 50 meters apart. The copter flies at 120 meters above the ground, so that pictures taken along adjacent tracks will overlap by 50 percent at the edges. This overlap is important to provide a seamless point cloud product.  550 by 550 is an unprecedented collection size for Ecosynth.  Layed end to end, the flight is 7.8 km long, more than twice as long as out previous flight standard: 275 by 275 meters.
3689528524?profile=originalThis screenshot from Google Earth displays the actual path followed by Wolfgang while it was gathering pictures. It managed to follow its router with great precision. I estimate it deviated no more than two meters from its planned track at any given time. In addition, according to the telemetry it very rarely dipped below 119.5 meters or 120.5 meters, so the altitude was very consistent. The groundspeed reported that it flew between 7 and 9 m/s along the tracks, which is well within desirable parameters. The photo collection took 20 minutes to fly over all 12 tracks, and the entire flight took 25 minutes including takeoff and landing.
3689528660?profile=originalAn example photo from the set. Wolfgang recorded 2250 pictures in the collection area, all of which were sharp and detailed like this one. The sun was bright and unclouded, so the lighting was consistent throughout the entire flight. These favorable conditions and outstanding copter performance resulted in a very consistent and detailed point cloud. The pictures were run through Photoscan to produce this point cloud:
(View in HD and use fullscreen to gain the full effect. At least, the fullest effect that can be gained without manipulating the cloud yourself.)
Blog post cross posted from the Ecosynth blog.
  • I've acquired three cameras for mapping:
    - The Canon A3400IS (which was horrible in terms of image quality). It never flew.
    - The Ricoh GR Digital IV (quite nice, 10MP, good quality picture, but had issues with focusing, specifically that at least on mine, the "tilt" sensor caused the infinity focus setting to invert when pointing below the horizon. Really strange. It's using a very specific USB plug as well, so difficult to replace. But works very well over a good range of voltage for camera triggering without any specific CHDK adjustment (CA-1 protocol).
    - The Canon IXUS 230 HS (going to use this from now on). This camera is very light, very small form factor, has a very good image quality for its cost and can be loaded with CHDK. Its disadvantages:
       * Doesn't save infinite focus setting
       * Doesn't power on and extend the lens when applying 5V pulse first time, so turn on when about to go flying and then set the infinity focus setting.
    On all cameras I always had the IS setting off, as the frequency of vibrations is so high that it hurts more than it helps.
    Also note the specific model names of the Canon range. It is very easy to mix up an Elph with an Ixus if you're not careful, so double check you're getting what you want.
    If anyone knows how to get the Ixus to power on/off automatically, I'm all ears.
  • I see your using the ELPH 520. This camera has OIS (optical image stabilization) which utilizes "floating" lenses that are gyroscopically controlled. This system, whether on or off, is terrible for rc applications due to the vibrations causing the lenses to shake enough to blur the images.
    At least, this is the case on my Canon s95. Ive read other people having the problem on different model Canons with OIS. You seem to not have this problem though? Have you effectively isolated the camera from all vibes, or does this ELPH use some sort of different OIS than the s-series?
    I ask, because Im looking for a new camera to replace my S-95 for aerial mapping.
    thanks,
    Matt
  • Very impressive and inspirational work! Thanks!
  • T3
    Nope, unfortunately there is no CHDK available for the ELPH 520.  We simply set it to continuous shooting with constant aperture (for consistent lighting), calibrate it on a grey calibration card for the first photo, and Velcro the shutter button down.  It takes two pictures per second.
  • How did you activate the shutter on the cameral? CHDK?
  • T3
    Hugues: our octos use MK3838 motors with APC 12x3.8 props.  The all up weight is a hair under 4kg!
    Mikrokopter.us
  • MR60
    Wow impressive ! And very nice flight time.
    -What size props and what motors did you use ?
    -What is the total AUW weight (with batteries) ?
  • Wow this is awesome!  The flight plan on mission planner is a really nice way to make a 500 by 500 meter collage :)
