Electronics arrived - assembly
Finally got my 'Tronics from the store
Up to the assembly work !
3689396483?profile=original
3689396500?profile=original
The boring work completed after a couple of minutes:
3689396509?profile=original
Soldering the magnetometer:
3689396392?profile=original
Had to solder the GPS to the header because the store didn't have the GPS cable
GND to GND, 5v to VCC,
TX on the APM to GPS IN
RX on the APM to GPS OUT
3689396526?profile=original
connecting...
that makes a nice sandwich !
3689396609?profile=original
and...
checking the reading....
SUCCESS !
Only the GPS is not outputting data...
I've checked in the terminal sending "S" during flight mode, but all the numbers in the end are 0.0000
the led on the GPS is constantly on after certain time... dont know what this means.
maybe it doesn't get enough satellites from my window ?
  • It's on the configurator, just select 'raw sensor data'
  • @ AR
    Could you please tell me how you've got those graphs (Outputs), that show the Roll, Pitch and Yaw.
    Thanks !
  • solved by sending '4' instead of 'S'
  • I had the same problem. I got only ............................ symbols and not any more.
    I solved this problem by changing "GPS_PROTOCOL_MTK" with "GPS_PROTOCOL_MTK16" in apm_config.h.
    My gps works even in the house not far from the window - about 4-5 meters.
  • I've just spotted that "0.7071" appearing in the command terminal is part of the exact latitude i'm at.
    but no signs for pars of the longitude (should be 34,50,13)
  • ok
    now this give me
    i cant find the coordinated (it should be 32....,34....)
    #################### GPS LED BLINKING ###############################
    0,3,0,-1,0,8,29,0,1040,1040,1040,1040,-29,39,421,1.4329,0.1375,0.9905,65,201,-363
    0,3,0,-1,0,10,29,0,1040,1040,1040,1040,-29,41,420,1.5552,0.0156,0.9999,43,204,-374
    0,2,0,-1,0,11,28,0,1040,1040,1040,1040,-29,41,421,1.4924,0.0783,0.9969,54,186,-381
    0,3,0,-1,0,11,28,0,1040,1040,1040,1040,-29,41,422,1.5049,0.0659,0.9978,50,183,-365
    0,3,0,-1,0,12,28,0,1040,1040,1040,1040,-30,41,422,1.4327,0.1377,0.9905,63,202,-349
    #################### GPS LED CONSTANTLY ON ###################
    0,2,1,0,0,-25,119,0,1040,1040,1040,1040,31,297,324,-0.7893,0.7044,-0.7098,329,-336,188
    0,2,1,-2,0,-25,119,0,1040,1040,1040,1040,32,298,324,-0.7810,0.7102,-0.7040,321,-327,192
    0,2,2,-2,0,-25,119,0,1040,1040,1040,1040,31,297,325,-0.7696,0.7182,-0.6958,335,-316,168
    0,1,1,-1,0,-25,119,0,1040,1040,1040,1040,31,297,325,-0.7855,0.7071,-0.7072,329,-321,166
  • OK,
    I'm going here http://code.google.com/p/ardupirates/downloads/list
    what should i download ?
    and to i just put it in the arduino sketch dir and upload it like the RC2 ?
    No, don't use RC2.  Use the ArduPirates code instead and select MTK16 as your GPS.
  • I've read somewhere that some codes are not compatible with some versions of the GPS...
    the GPS says MEDIATEK-V12. i'm using the RC2 code - are they good friend ?
    does it need some special config in the code to turn the GPS on ?
    Yes, it's hard to get GPS lock inside
