EMC Shielding for ArduCopter3.0
The EMC shielding material reduce magnetic interference that is good to ArduCpoter3.0.
Measurement of magnetic interference becomes half by 60micron meter low-loss,high permeability nano-crystalline material.
3689532263?profile=original
Without magnetic shield
3689532249?profile=original
Magnetic shield applied
3689532347?profile=originalMagnetic shield material is Hitachi FINMET low-loss,high permeability nano-crystalline material.
http://www.hitachi-metals.co.jp/e/prod/prod02/p02_03.html
Similar material from 3M™ High Permeability Magnetic Shielding Sheet 1380 will also work.
  • If this works like MU Metal as in TC3's posting it can definitely seriously reduce the Magnetometers sensitivity as well.
    Putting a magnetometer in a Mumetal box pretty much guarantees the magnetometer will not see the Earths magnetic field at all.
    I think you would definitely need to use it only around the DC field emitting parts nad far enough away from the magnetometer so that the damping effect would not be noticeable.
    All things being equal, this might decrease the sensitivity of the magnetometer to the Earths field at about the same rate that it decreased it's sensitivity to the surrounding undesirable magnetic fields, net gain = 0.
    All I'm saying is that this solution can have some downsides and you need to understand that going in.
    @monroe: i have the same concern. This will shield not only the power electronics but the earths mag field from the APM. It makes me think if the earths mag is strongest through the Z axis that we need the mag sensor underneath the MAV and shielded, not above the PDB with the GPS?
    @scott: magnetic field creation is a function of the rate of change in current. The size of cable is irrelevant. The wires thickness only relates to ability to carry current, a thicker wire can support a faaster rate of change in current and a higher mag field. Selecting thinner cable just means a higher chance of cable failure.
  • where we can buy it
  • Thanks John..  Is it also accurate that undersized DC power cables will generate stronger fields than properly (or over-) sized cables?
    Magnetic interference are low frequency (DC) fields. The main source of such noise in a copter then obviously is the DC power cables drawing high currents and the battery. Twisting the DC power cables should help.
    ESC and motor phase wires generate high frequency AC fields, and are to my knowledge not problematic (within reason) for sensors. This is also why a normal conductive material like copper tape will not help. A conductive shield (Faraday cage) will only block AC fields and not a static DC field.
  • @Scott, All of the above.
  • Does anyone know what components actually are responsible for creating most of the magnetic interference?  Is it the DC power cables, ESCs, motor cables, or the motors themselves?    Wondering if it's worth trying to twist DC cabling where possible.
  • I am going to give this a shot. I have some interference and vibration issues that Oliver pointed out. Hopefully it will be as simple as putting a piece of this under some moongel and putting the APM on top of that.
  • how does this compare to, say, copper tape connected to ground?
