Enhancing UAV Applications with the TS1224 Laser Rangefinder(LRF) Module
Unmanned Aerial Vehicles (UAVs) are increasingly used in diverse fields such as surveying, mapping, agriculture, search and rescue, and defense. A crucial component that greatly improves UAV performance is a reliable laser rangefinder. Our TS1224 Laser Rangefinder Module is designed specifically to meet the needs of UAV developers and enthusiasts, providing long-range, high-precision distance measurement in a compact and rugged form factor.
13695863656?profile=RESIZE_710x
Key Features of the TS1224 Laser Rangefinder Module
  • Long Measurement Range: Capable of measuring distances from 5m up to 2000m, making it suitable for both short-range navigation and long-distance observation.
  • High Accuracy: Delivers precision of ±1m at ranges below 200m and ±0.5% for longer distances, ensuring reliable data for UAV flight control and mapping applications.
  • Compact and Lightweight: With dimensions of 25.72 × 24.6 × 13.4 mm and a weight of only 10g, the TS1224 is easy to integrate into drones without adding significant payload.
  • Rugged Design: Built with a metal housing, the module ensures durability and resistance against environmental stress, ideal for outdoor UAV missions.
  • Wide Temperature Range: Operates reliably between -20°C and +50°C, and can be stored at -40°C to +70°C, making it suitable for extreme field conditions.
  • Eye-Safe Laser Technology: Uses a 905nm Class 1 invisible laser, certified to IEC 60825-1, ensuring human eye safety during operation.
  • Low Power Consumption: Consumes only 210mW at 3.3V, making it energy-efficient for UAV systems where battery life is critical.
  • Stable Communication: Supports UART interface with TTL (3.3V) level and a default baud rate of 115200bps for easy integration with flight controllers and onboard computers.
13695863094?profile=RESIZE_584x
Advantages of Using TS1224 LRF Module on UAVs
  1. Obstacle Detection and Avoidance By providing accurate distance measurements in real-time, the TS1224 helps UAVs detect and avoid obstacles such as trees, power lines, or buildings, ensuring safer flight operations.
  2. Altitude Measurement The module enables precise altitude measurement above ground level, which is essential for terrain-following flights, precision agriculture, and low-altitude surveying.
  3. Target Ranging for Mapping and Surveillance With its long 2000m range, the TS1224 can be used in aerial surveying, wildlife monitoring, and surveillance missions, allowing UAVs to measure distances to objects or terrain features from afar.
  4. Compact Integration Its miniature size and lightweight body allow UAV designers to integrate the module even in small drones, without compromising flight endurance or maneuverability.
  5. Reliability in Harsh Conditions The metal enclosure and wide operating temperature range make the TS1224 reliable for UAVs operating in deserts, cold climates, or high-altitude environments.
Applications in UAV Systems
  • Aerial Mapping and Surveying: Accurate distance measurement improves the quality of topographic maps and 3D models.
  • Agriculture: Used for precision altitude control in crop spraying drones and field monitoring UAVs.
  • Search and Rescue: Helps drones measure distances to terrain features and navigate safely in complex environments.
  • Industrial Inspections: Ideal for drones inspecting tall structures, wind turbines, or transmission lines.
  • Defense and Security: Supports UAV-based reconnaissance by providing reliable ranging data at long distances.
13695863855?profile=RESIZE_710x
Conclusion
The TS1224 Laser Rangefinder Module is an excellent choice for UAV developers looking for a compact, efficient, and precise distance measurement solution. Its long-range performance, lightweight design, and rugged construction make it highly adaptable for various drone applications. Whether for obstacle avoidance, altitude measurement, or target ranging, the TS1224 enhances UAV capabilities and ensures safer, smarter, and more reliable operations.
Welcom to contact us: https://lasersensor.net
