🛰️ Enhancing UAV Precision: Real-World Tests with the Benewake TF-Luna LiDAR
Summary: We’ve been testing Benewake’s TF-Luna LiDAR on multirotor UAVs to evaluate how a sub-10 gram sensor performs in real flight conditions. The results show impressive precision and stability for low-altitude control, obstacle avoidance, and terrain following — all at a fraction of the cost of larger LiDARs.
Hi everyone, we’re an engineering team focused on UAV sensing and LiDAR integration. Over the past few months, we’ve tested the Benewake TF-Luna LiDAR across several drone platforms to evaluate how compact LiDAR modules perform under real flight dynamics. Our goal was simple: find out whether a lightweight, low-power sensor can deliver reliable altitude and obstacle data in outdoor sunlight and vibration.
It turned out — it absolutely can.
13768284053?profile=RESIZE_710x
⚙️ Technical Overview
The TF-Luna is a single-point Time-of-Flight (ToF) LiDAR, purpose-built for short-range, high-frequency distance measurement. Despite its small form factor, it delivers strong consistency and precision suitable for flight control and perception tasks.
ParameterSpecification
Range0.2 m – 8 m (Indoor) / Up to 3.5 m (Outdoor Sunlight)
Accuracy± 6 cm
Update RateUp to 250 Hz
Resolution1 cm
InterfaceUART / I²C
Operating Voltage5 V
Average Power Consumption< 0.35 W
Weight≈ 10 g
Dimensions35 × 21.5 × 13.5 mm
Even under 70 klux sunlight and continuous rotor vibration, the TF-Luna maintained stable readings with minimal noise. Integration through UART or I²C with Pixhawk, ArduPilot, or Arduino controllers was straightforward — requiring only standard serial communication.
🚁 Field Test Highlights
We mounted the TF-Luna on a 1.5 kg multirotor and ran a series of outdoor flights between 0.5 m and 6 m altitude. Results showed:
  • Stable distance readings within ± 5 cm of a reference laser rangefinder
  • Zero signal dropouts at 250 Hz update rate during fast throttle changes
  • Accurate landing data even on uneven ground
That level of precision and responsiveness makes it perfectly suited for UAVs that rely on real-time distance data for autonomous takeoff, landing, and terrain following.
🧭 UAV Applications
  • Altitude Hold – Improves hover stability when barometric sensors drift
  • Obstacle Avoidance – Detects nearby structures in both indoor and outdoor flights
  • Landing Assistance – Provides accurate ground distance during descent
  • Terrain Following – Maintains constant height over crops or irregular surfaces
  • Swarm Sensing – Multiple modules can be used for multi-directional obstacle detection
At under 10 grams and 0.35 W consumption, TF-Luna adds negligible weight and power draw — perfect for compact UAVs or multi-sensor payloads.
🔋 Compact Power, Serious Performance
We often struggle with sensor trade-offs in UAV design: every gram matters, and every watt shortens flight time. TF-Luna solves both. It’s one of the few modules we’ve found that combines low cost, low power, and data reliability — a rare combination in the LiDAR category.
For developers experimenting with swarm drones, indoor navigation, or robotic platforms, it’s an easy addition that upgrades spatial awareness without burdening the system.
🌍 Why It Matters
LiDAR provides what other sensors can’t: quantitative certainty. While cameras interpret scenes, LiDAR gives hard numbers — the distance data your flight controller can trust. By offering accurate, low-latency measurements at a reasonable cost, the TF-Luna bridges the gap between research-grade sensing and consumer-level accessibility.
It’s helping more UAV developers — from hobbyists to research teams — build safer, smarter autonomous systems.
🔗 Learn More & Collaborate
We’ve documented our setup process, test results, and integration examples here: 👉 www.lidartechsolution.com
If you’re working on UAV autonomy, terrain mapping, or LiDAR-based sensing, we’d love to exchange data, results, or integration tips. The DIYDrones community has always been at the frontier of UAV innovation — and compact LiDAR modules like the TF-Luna are key to taking that frontier further.
Benewake TF-Luna — small form, precise vision, flight-proven reliability.
