Experimenting with Sony's QX100 Wifi camera
3689567167?profile=original
Interesting research from UCSD on using the innovative Sony QX100 for UAVs.
The QX100 features a Wi-Fi interface for control via a smartphone, so we thought we’d slap it on the copter and see how far it could go.  Testing with a number of Android devices on hand, we quickly determined that that was not viable, with the liveview lagging and failing soon after the copter took off.  In an attempt to scrounge up more signal strength without adding weight to the copter, we decided to experiment with a USB Wi-Fi dongle and a directional antenna connected to a laptop.  To interface the camera to the laptop, we turned to Sony’s Remote Camera API, and wrote a python script that would allow us to command image captures, as well as display a liveview so we can frame our shots.  This was moderately successful, with some dropped frames but an otherwise stable link at 200ft, though it was not a very smooth experience.  Both the software and hardware setups have room for improvement, so this is an encouraging first result.
3689567206?profile=original
We are releasing the interfacing script open source so others can experiment with it, and possibly apply it to other interesting projects.  All of Sony’s Wi-Fi enabled cameras use the same interface, so the script should work on other cameras such as the NEX-5T as well, though it will likely need to be modified for the appropriate IP address, as we did not implement the device discovery.  Note that this is still under development, so it has issues and is not yet user friendly.
3689567099?profile=original
We had much more success with the second approach we tried, mechanically triggering the shutter button with a servo driven from the Ardupilot.  Using this method, we were able to quickly and reliably capture images, but without a liveview, framing the picture was difficult.  This is relevant for aerial photography, but not for survey missions where the camera should be triggered regularly.  Unfortunately, the QX100 has a habit of turning itself off when inactive, which seems to mean not being connected via Wi-Fi, so it cut out the last half of the attempted mapping mission.
The optimal approach we are now aiming for is to have a Wi-Fi liveview with a repeater on the copter to see what is going on while triggering captures with a servo to ensure consistent and reliable image capture.
In terms of achieved image quality, the QX100 is currently not well suited for aerial mapping missions.  Due to lack of a shutter priority mode, program auto often chooses slower shutter speeds, which causes significant motion blur from the moving copter.  The good news is that it works well while pointed forwards, as shown in the image gallery below.  Sony is releasing a new firmware update for the camera at the end of January 2014 that provides a shutter priority mode, so we will try again then.
  • Draganflyer uses the qx100 on their uav. The gimbal and camera looks more aerodynamic than the gopro and the picture reportedly is much better. http://www.draganfly.com/uav-helicopter/draganflyer-guardian/index.php
  • No, John, i does not mess with the compass, but i havent installed things into the copter yet.
    I bought one two month ago and yet interface it with VR Radio under development :)  It work very good the only limit is that preview is sent in mjpg format that's is not a great compression algorithm as .mp4 .
    On SD card the video is great :)
  • I do the same thing with a Sony Nex-6. I use a Raspberry Pi onboard with a wifi usb adapter connecting to the camera. I have an ongoing build of a Windows application/.NET) on the GCS to communicate with the RPi via 3g or my long-distance wifi (Alfa 2000mw+IBCrazy antennas). This software (when finished) has live preview and takes photos in different ways remote :) Cool!!
  • Cool! like the direction this technology is heading.
  • Interesting work.  I posted a blog about these cameras a few months ago.  I think they show a lot of promise, but obviously are not quite the killer app just yet.  Hopefully within the next year somebody (Sony, or somebody else) can get these things working for us.
    What a shame that in 2014, you have to drive the shutter with a servo ziptied to the camera. :(
  • I`ll be interested how you go,I have looked at the QX100 and wondered how long it would be until someone had a crack at it.
    Good luck.
