For UAV developers, adding a distance sensor is not just about measuring how far away an object is. The sensor also needs to deliver usable data at the right rate, communicate reliably with the onboard electronics, and perform consistently under real operating conditions.
One option worth exploring for custom measurement payloads is a phase-based laser distance sensor such as the LDJU, which uses indirect Time-of-Flight (iToF) technology.
Why Does Measurement Frequency Matter?
When a UAV is moving, the distance to a target can change continuously. Depending on the application, a low measurement rate may provide enough information for occasional inspection, while a higher rate can offer more frequent updates for dynamic measurement experiments.
The LDJU version discussed here supports continuous measurement frequencies of up to 10 kHz under specified operating conditions. Its stated measurement range is 0.2–30 m, with a measurement resolution of 1 mm.
These specifications may make it worth evaluating for custom UAV payload prototypes that require frequent distance readings over short to medium distances.
However, a high measurement frequency does not automatically guarantee better results in flight. Target reflectivity, ambient light, vibration, sensor alignment, data processing, and timestamp synchronization can all affect the usefulness of the measurements.
Potential UAV Development Applications
Depending on the payload design and field-test results, a high-rate distance sensor could be explored for applications such as:
Inspection payloads: collecting distance readings while a camera observes structures or equipment.
Proximity measurement experiments: evaluating how distance data behaves as a UAV approaches a target.
Motion and measurement research: comparing sensor readings with UAV position and payload orientation.
Custom robotic systems: integrating laser distance data into an onboard controller or companion computer.
These are potential development applications, not pre-validated LDJU integrations. The appropriate configuration depends on the required range, target surface, environmental conditions, and system-level testing.
Interface and Integration Considerations
The LDJU interface depends on the specific version. Available options include USB 2.0 or USART, while RS232 and RS485 communication may be supported through an external level-conversion module.
Before integrating the sensor into a UAV, developers should verify the exact interface and electrical requirements of their unit. They should also confirm that the onboard controller can receive and process data at the intended measurement rate.
A practical evaluation could begin with a bench test:
Connect the sensor to a suitable power supply and host controller.
Record continuous distance readings at several known target distances.
Check data continuity and measurement stability at the intended update rate.
Repeat the test with different target surfaces and lighting conditions.
If the sensor is mounted on a moving payload, test the effects of vibration and orientation changes.
For applications requiring synchronized measurements, recording timestamps alongside distance data is also important.
Resolution Is Not the Same as Accuracy
The LDJU specification lists a measurement resolution of 1 mm. Resolution describes the size of the measurement increments; it should not be interpreted as a guarantee that every reading is accurate to within 1 mm.
The manual specifies accuracy separately as ±(3 mm + D × 1/10000), where D is the measured distance. Actual performance can also depend on the operating environment and target characteristics.
For UAV applications, it is therefore important to evaluate both the specified accuracy and the repeatability of readings under representative test conditions.
A Starting Point for Custom Payload Development
The LDJU provides a measurement range of 0.2–30 m and continuous measurement frequencies of up to 10 kHz for the version discussed here. These characteristics offer a starting point for developers investigating high-rate distance measurement in custom embedded systems.
As with any sensor intended for use on a moving platform, suitability should be confirmed through mechanical, electrical, and field testing rather than inferred from the datasheet alone.
For more information about Meskernel's laser distance measurement solutions, visit Meskernel or contact us.
When evaluating a high-rate distance sensor for a moving UAV payload, which factor has the greatest impact on your design: measurement frequency, accuracy, interface bandwidth, or stability under vibration?
