3689660615?profile=original
The flying wing design I have been working on for some time now has been slowly evolving as I have learned more about aerodynamics and expanded my skill set with modelling tools of various forms.  I have recently completely re-surfaced my design with new aerofoil sections and better, more consistent surface transitions and have been experimentally analysing the results with CFD, courtesy of OpenFOAM.  I want to present some of the results here to share.
The lead image is the latest design iteration analysed in OpenFOAM at close to stall angle of attack and the following are a couple of renders of the latest surfacing.
3689660736?profile=original
3689660756?profile=original
Along with developing methods, I have learned a few things about what makes flying wings tick and how they can be better optimized, at least in the genre that I am pursuing.  Some interesting, I hope, insights follow:
Aerofoil selection appears to be the one thing many obsess over when designing a flying wing, but I have found it is only a very small part of the equation and gains made here in two dimensions can be easily lost in the transition to 3D.  Many flying wings appear to fly with a large amount of elevon-induced reflex, demonstrating that aerofoil selection alone is inadequate.  In a sense, it is equivalent to a large decalage angle to compensate for a low tail volume which is a pretty inefficient way of achieving the design objectives.
I have several iterations of aerofoil in this design, a root foil whose origin is now unclear and a tip foil which started as a symmetrical NACA foil, but wound up with a little camber in the end.  Much of the initial development was done in XFLR5 but the CFD proved illuminating in areas not possible with panel code alone.
Washout has proven to be a much more powerful tool to add pitch stability and, in both geometric and aerodynamic senses, has surprised me in how much is actually required to do the job.  I have about 7° geometric in this design and in addition have an inverted aerofoil section (a NACA 1308)) for the wingtip to add a relatively large amount of additional aerodynamic washout.  Despite this, the undeflected trim speed of this design is of the order of 24-25m/s  At this Reynolds number scale, washout has an advantage over reflex that hopefully will become clear shortly.  The next image shows the airframe at about 24.5m/s and demonstrates pretty clearly the lift distribution through the downwash trajectory.
3689660808?profile=original
One of the big hurdles of flying wings is to maximize the CLmax value which determines the maximum wing loading and landing speeds.  Despite the large washout, the stall consistently begins around the tip which is where much of my attention has been focused.
Early on in my investigations I discovered that wing sweep can have deleterious effects on stall performance.  In hindsight, I was rediscovering what the Russians already knew from their MiG15 design onwards and attempted to alleviate with those huge wing fences.  The effect of wing sweep at stall is a reverse spanwise flow on the upper wing surface.  In part this is caused by a changing spanwise pressure gradient as the AoA increases where the inboard high pressure zone is interacting with the lower pressure zones further outboard.  The boundary layer flow model below helps visualize this flow regime quite dramatically, although at this Re scale, I predict that it tends to form a laminar separation bubble/vortex running span-wise along the wing surface.
MiG-17F_Top_View.JPG?width=750(MiG-17 showing clearly the wing fences for controlling reverse span-wise flow at high alpha)
3689660778?profile=original
As demonstrated in the above illustration, the design optimization of the elevons is an area that is ripe for further DIY exploration.  I have found that traditional full-span elevons are counter productive because as the elevon reflex is added, the aerofoil section CLmax is reduced.  I have instead experimented with various size and proportion elevons at the wing tips, leaving the inboard wing section unmodified with control surface deflection.  This elevon design appears to do the job of increasing the aerodynamic washout of the wing as much as adding reflex, both effects working in parallel to reduce its trim speed accordingly.  Unfortunately the foil section modified by the deployment of the elevons tends to be negatively affected giving rise to a large adverse pressure gradient early in the chord causing flow separation bubble formation and loss of lift - the bubble in effect causing a dramatic thickening of the effective aerofoil section with a near total loss of reflex.  For this reason, I think washout provides some interesting advantages over reflex at this scale.
To alleviate this separation bubble phenomenon, I have experimented with the use of  "spoilerons" - in effect a kind of inverted split-flap design.  The top surface of the foil section is deflected upwards leaving the bottom surface unmodified.  By opening a gap at the leading edge of the spoiler surface as it is deployed, the negative pressure behind the spoileron tends to improve the pressure gradient along the foil boundary layer helping to delay the inevitable separation somewhat.  The spoilerons have also appeared to be extremely effective at quite small sizes relative to conventional flap-type elevons and have led to a minimal impact on drag at low angles of attack.
Spoilerons have not entirely solved the problem of wingtip flow separation so I have added leading edge slots in this latest design iteration.  I would not consider them yet optimal, but they tend to add about 4-5% to the CLmax as they stand.  They also may have had a non-trivial impact on CD0, but I haven't yet enough data to demonstrate or quantify this.
3689660628?profile=original
The results so far predict a best L/D just shy of 12:1 at around 16-17m/s with a span of 975mm and a 1.2kg AUW.  There is a small non-linear effect with weight variation due to Reynolds number effects at this scale, some of which can also be seen in the measured drag polar data, where drag at high AoA increases much more sharply than predicted by conventional drag coefficients.  This is almost certainly a result of separation bubbles forming - at least theoretically.  I don't wish to imply that the CFD data is infallible.
Despite the use of CFD, I haven't yet managed to achieve my theoretical design goal of 10m/s stall speed at the design weight (1.2kg).  It currently sits somewhere in the region of 11m/s for a CLmax of 0.65-ish.  Note that the reference area is close but still a little unclear at this point due to the "flowing" wing planform so the lift coefficient data probably isn't directly comparable.
3689660791?profile=original
V-LD%20Graph_zpsyklpwjrb.png?width=750
I am doing further analysis based on these aerodynamic characteristics to establish propeller selection, range, payload, climb performance, battery size etc, however initial estimates are very encouraging, putting range at or exceeding 100km on 8 x NCR18650B's.  With careful airframe design, this allows for at least a 250g payload as well as both video (5.8GHz) and telemetry (915MHz) data links aboard.
I envisage a fully moulded composite airframe to meet the weight targets, make it robust and to yield a good surface finish for drag minimization.  Along side this work, I have been experimenting with some construction techniques on a winglet sample.  The results of this experimentation will help drive some of the design and strutural analysis.  The potential for high quality surfaces is definitely there but will take some process development and an amount of overly sticky fingers to achieve.
a7566849-235-20150213_133633_1024.jpg?width=750
a7566847-42-20150213_133532_1024.jpg?width=750
There are a bunch of detail design issues yet to resolve, not least being the manufacturing methods for a robust spoileron at an affordable cost.  The non-trivial issue of downward control surface deflection has also to be addressed in mechanical and aerodynamic terms.
Unfortunately as this is all self-funded to date, so progress will continue apace, where the pace will be more tortoise than hare.  I hope to publish further info about how I've gone about range analysis, propeller selection as well as some more details about how I've used CFD.
Thanks for reading if you've got this far.  I hope it's been interesting
  • @Andrew, CL distribution is not the same thing as lift distribution. CL distribution determines the stall characteristics. With 7 deg washout the tips might indeed be ok, but it will be a one speed plane.
    10% static margin is also pretty high. Lowering it will improve performance. You can't expect to have the same SM and performance as a tailed airplane.
  • @Howard, the winglet is 2 layers of 18gsm plain weave glass with epoxy on the mould surfaces with expanding PU foam filling just prior to mould closure.  Result is light (<20g) and robust, but not yet perfect surface finish.
  • Lift distribution is pretty clearly obvious from the downwash streamlines in the fourth picture.  Wingtips are a long way from overloaded - negative lift under most scenarios.  If there was lots of lift at the wingtips, you'd see it in the streamlines as vorticity.
    CFD is agnostic regarding the 2D aerofoil profile and polars.  It's only calculating the pressure distribution created over the body as a whole which is integrated to calculate total lift and pitching moment relative to datum.
    If you have limited washout (i.e. circa 2° as Vladimir proposes) you wind up needing large elevon deflections to create enough reflex for balanced flight at reasonable speeds  (I'm assuming 10% MAC ahead of NP for static margin for my calculations)  Without extreme reflex, you need much more washout to match zero control deflection speed to anywhere near max LD speed.  Basically at a minimum with your root foil at best L/D AoA, your tip foil will be at zero to negative AoA to give balanced flight.
  • Would love to know more about your construction techniques on a winglet. That mould looks amazing.
  • 7° is probably too much. It's even possible to use cambered airfoils on a flying wing with very little washout. Though it's probably not possible with such a small plane.
    Seems like your design has quite a lot of sweep (around 25 deg?). That together with the small tip chord severely overloads the tips. Could you post the CL distribution for the wing?
    I have about 7°
    Trash...
    If you calculate more, than 2 degree - start calculation again.
    Well written and informative. And I have to agree with Gary.
    Very very nice, glad to see this sort of post back on DIYD.
