Here the fuse halves are joined with masking tape and the inch and a half seam tape is applied to the bottom.
Landing gear being molded into the bottom and will be sanded smooth after resin sets. The long brush on top will be used to apply the seam tape to the inside top portion of the fuse.
Rear wheel temporary fit test.
Rear belly hatch used to appy seam tape, later to be used as servo acess.
It is almost impossible to beat elpour EasyStar !
But this one also seem really pretty good !
Hats off to you !
Earl
Earl....back from Haiti
