Some more immpressions can be read and firmware can be dowloaded here - http://www.rcgroups.com/forums/showpost.php?p=13667448&postcount=294
May I know whether the measured CRS data from GPS EM406 is accurate?
Thank you (:
Earl
BER, yes can be used as arrows to indicate the direction of the WP destination.
BER will change, if you switch to RTL automatically the BER will point to home, if you are in manual mode the BER will point to home, if you are in waypoint mode BER will point to the waypoint direction, so would be nice if you use always the arrow with BER...
BER: angle of wp to plane in degrees - so can be used as arrow do actual WP destination ?
Or maybe arrow all the time will point the home only ?
WPN: waypoint index - this OK , 0 will indetyfy home - that I already knew :) .
RSP: angle of rudder in degrees - what is that exactly ? how to interpret this ?
or watch this movie https://www.youtube.com/watch?v=gwKxMZkFVtg
1
2
of 2 Next
