Looks like a good fpv/camera ship for long distance flights with ArduPlane.
$189 - airframe kit only
http://www.readymaderc.com/store/index.php?main_page=product_info&cPath=101&products_id=2482
Specifications:
- Wingspan: 2520mm / 99.2inch
- Kits Airplane weight: 2.4kg (5.3lb) including all reinforcement parts
- Extra Payload: 3.0kg-4.0kg (6.6lb-8.8lb)/ flight weight>6.0kg
- Customized Brushless Power system:
- Customized Motor for Airtitan: M60K/ Power 1500W
- Testing static thrust: 5.5-6.0kg (6S, 15" Prop)
- Propeller recommend: 15*6 / 15*7
- ESC: Advanced 80A OPTO (without Built-in BEC)
- External UBEC: 5V/6A,5.5V/6A or 6V/6A (Switchable)
- Material of fuselage and Wing: EPO
However notice
There are some advantages to this aircraft.
My 0.22 cents worth:
- Looks like no flaps, only ailerons and ailerons don't go to the wingtips
- enormous black aileron hinges
- twin vertical fins seems unnecessary and they're slightly out of the propwash (but they are big)
- added weight of extra fin, rudder, servo and hardware.
- empty weight seems a bit heavy
- 1500W, for what!? To test flutter? Go into orbit?
Is that flush servo's I see in the wings? If so, I'm surprised we don't see more direct-drive servo use. I understand there are packaging reasons to use linkages, but even still - would like to see more direct drive use - less bits to go wrong, and more aerodynamically efficient.
too many tails!
If only they included a propeller in deal it would be a no brainer :) Looks the part,like the broad wings.
Its going to be upto the first 50 folks that buy it to get the truth out.On paper it looks cool. (and in that shot)
