HMC5883L is a 3-axis digital compass from Honeywell. Communication with the HMC5883L is simple and all done through an I2C interface. There is no on-board regulator, so a regulated voltage of 2.16-3.6VDC should be supplied.
This breadboard-friendly board breaks out pins to a 4-pin 0.1" pitch header. We've also put two 10k pull-up resistors on the I2C lines.
Features:
Simple I2C interface
2.16-3.6VDC supply range
Low current draw
5 milli-gauss resolution
Dimensions:
15.2x15.2 mm
0.5 gram
Documents available for download:
Schematic: http://www.flytron.com/pdf/HMC5883L_schematic.pdf
Datasheet (HMC5883L): http://www.flytron.com/pdf/HMC5883L_datasheet.pdf
Arduino Example code: http://www.flytron.com/pdf/HMC5883L_example_code.zip
Price is US$ 13.95 (sale price, not sure how long it holds...)
More information at the Flytron site: http://store.flytron.com/sensors/142-hmc5883l-triple-axis-magnetometer-breakout.html
