FMS F4U-4 Corsair 1100mm PNP RC Plane
The FMS F4U-4 Corsair with a 1100 mm wingspan combines the distinctive appearance of this legendary warbird with a powerful 4S brushless power system. Its characteristic inverted gull wing, scale four-blade propeller and detailed finish create an impressive presence on the ground and in the air.
more info:
https://www.fms-model.com/fms-f4u-4-corsair-1100mm-pnp-rc-airplane.html
The fuselage and wings are made from lightweight, durable EPO foam. Engraved panel lines, external tanks and a pitot tube enhance the scale appearance. Integrated lighting adds realism and improves the model's visibility.
The installed 3536-KV750 brushless motor and 40 A ESC are designed for a 4S LiPo battery. A thrust-to-weight ratio exceeding 1:1 provides powerful climbs and dynamic flight manoeuvres. Six pre-installed 9 g servos operate the control surfaces and flaps.
Functional flaps support slower, controlled landing approaches. Retractable landing gear maintains a clean scale outline in flight, while sprung metal landing gear struts absorb impacts during touchdown and taxiing.
  • FMS F4U-4 Corsair 1100mm PNP RC Plane
Supplied as a PNP model, the Corsair comes pre-painted with the motor, ESC and servos installed. Final assembly and the addition of a suitable radio system, receiver, flight battery and LiPo charger are required.
Features:
  • Scale warbird in PNP configuration
  • Lightweight, durable EPO foam construction
  • Characteristic F4U Corsair inverted gull wing
  • Pre-installed 3536-KV750 brushless motor
  • Pre-installed 40 A ESC
  • Six pre-installed 9 g servos
  • Scale four-blade propeller with spinner
  • 4S power system with a thrust-to-weight ratio exceeding 1:1
  • Functional flaps
  • Retractable landing gear with sprung metal struts
  • Integrated lighting system
  • External tanks, pitot tube and engraved panel lines
  • Pre-painted finish with minimal final assembly required
Specifications:
  • Wingspan: 1100 mm
  • Length: 880 mm
  • Flying weight: approximately 1300 g
  • Wing area: 21.5 dm²
  • Wing loading: 60.5 g/dm²
  • Motor: 3536-KV750 brushless
  • ESC: 40 A
  • Servos: 6 × 9 g
  • Recommended battery: 4S LiPo, 14.8 V, 2200–2700 mAh, 25C
Product Included:
  • FMS F4U-4 Corsair 1100 mm PNP with motor, ESC and servos installed
  • Illustrated assembly manual
Required accessories – not included:
