FMS Ranger 1220mm PNP V2 with Reflex RC Airplane
More info:
The FMS 1220mm Ranger V2 Yellow RC airplane retains all of the fantastic features that pilots have come to expect from FMS- stable flight characteristics, easy to assemble airframe and realistic, general-aviation inspired design.
Built with ultralight EPO foam, the large, high-winged airframe configuration gives the Ranger low wing-loading and extraordinary amounts of lift, even at slow speeds. Robust plastic struts give extra strength to the wings during aerobatic maneuvers and the patented high-strength tricycle landing gear makes ground handling a breeze.
A great aircraft is nothing without a great, dependable power system and FMS has equipped the Ranger with a 3136/1200KV outrunner motor with 20A Predator ESC, which allows the Ranger to climb almost vertically on demand! In the box, the Ranger comes with two sets of landing gears- a high-strength metal landing gear for ground operations. Designed with a yellow and white high-visibility color scheme, the Ranger can always be easily orientated even in gloomy, overcast weather.
Like the Super-EZ and the Kingfisher, the Ranger is designed with ease of assembly in mind. Requiring only 6 (wheeled landing gear) to completely assemble, the longest wait time is the time it takes to charge the battery!
Also included FREE is FMS’s new Reflex System - an advanced flight control module designed to provide electronic stabilization while retaining natural flight characteristics.
Features
High-spec power system: 3136-1200KV motor, Predator 20A ESC
High strength, lightweight metal landing gear for all-ter-rain operations.
Screw-together and twist-lock assembly,completed in 3-10 minutes
10-15 minute flight times (RTF specification)
One piece horizontal stabilizer for precise flight character-istics
Specifications
Wingspan: 1220mm/48in
Overall Length: 947mm/37.3 in
Flying Weight: 1200g/oz
Motor Size: 3136-1200KV
ESC: 20A
Servo: 9g Servo x 5pcs
Radio: 4 Channel
CG (center of gravity): 50-60mm(From Leading Edge)
Prop Size: 10*5 2-blade
Recommended Battery: 3S 1300MAH 25C
Battery Connector: XT-60
Aileron: Yes
Elevator: Yes
Rudder: Yes
Flaps: No
Retracts: No
Approx. Flying Duration: 10 min
Minimum Age Recommendation: 14+
Experience Level: Intermediate
Recommended Environment: Outdoor
Material: Durable EPO
Required To Complete
4 channels Transmitter
4 channels Receiver
3S 1300mah 25C Lipo Battery and Lipo Battery Charger
AA small batteries for remote comtroler
FMS Avanti 90mm EDF Jet PNP RC Airplane
FMS F-16 Battlefield Gray 64mm Jet RC Airplane
FMS F-16 Thunderbird 64mm Jet RC Airplane
FMS Cessna 182 1500mm PNP Blue RC Airplane
FMS Cessna 182 1500mm PNP Red RC Airplane
FMS Integral 80mm EDF PNP Red RC Airplane
