FMS Super Scorpion V2 90mm EDF Jet PNP 6S Orange RC Airplane
FMS Super Scorpion V2 90mm EDF Jet PNP 8S Came Jet
Features
1.Improved CNC machined trailing link struts, ensuring smooth suspension and effectively reducing the impact force to the airframe during takeoff, landing, and taxiing.
2.Available in both 6S (3670-KV1950 inrunner motor) and 8S (4075-KV1500 inrunner motor) versions.
3.Available in two different paint schemes; orange and Orangeuflage!
4. Electric retracts with locked-rotor mode and over-current protection.
5. Multi-plug connectors for added durability, reliability, and ease of assembly.
6. Preinstalled ball link connector for increased throw and precision.
7. Screw-together assembly.
8. High-quality wear-resistant tires.
9. Buckle-design latch prevents unexpected canopy release in flight.
10. Flap functionality to help ease takeoff and landing.
11. Environmentally friendly water-based paint for better color and adhesion.
12. High quality EPO foam.
what is in the package Box:
(1) FMS 90mm Super Scorpion V2 Orange EDF PNP
(2) 120A ESC with Reverse Thrust Function (pre-installed)
(3) 6S 3670-KV1950 inrunner EDF motor pre-installed)
(4) 90mm 12-blade ducted fan (pre-installed)
(5) 9 High-precision All-metal Digital Servos (pre-installed)
(6) paper Manual
FMS Super Scorpion V2 90mm EDF Jet PNP 6S Came Jet
FMS Super Scorpion V2 90mm EDF Jet PNP 6S Orange Jet
FMS Super Scorpion V2 90mm EDF Jet PNP 8S Orange Jet
FMS Avanti 90mm EDF Jet PNP RC Airplane
FMS F-16 Battlefield Gray 64mm Jet RC Airplane
FMS F-16 Thunderbird 64mm Jet RC Airplane
It Requires:
(1) 6 Channel Transmitter and Receiver
(2) 6S (22.2V 5000mAh-6000mAh 45c with EC5 connector)
(3) LiPo Battery Charger
Notes to Buyers
RTF (Ready to Fly) airplanes come with everything you need to fly in the box. A transmitter, receiver, battery, charger, and all other required electronics are included and pre-installed from the factory.
PNP (Plug-and-Play) airplanes include the ESC, motor, and servos all pre-installed from the factory. Transmitter, receiver, battery, and charger are not included.
EPO foam and cockpits can bubble or deform in high heat. To prevent this, avoid leaving them in direct sunlight when not in use.
Reflex V3 is not included and needs to be purchased separately.
6-channel receiver is needed for Ailerons, Elevator, Throttle, Rudder, Landing Gear, and Flaps. Upgrade to 7 or more channels for advanced features like Thrust Reverse and Reflex Control.
Specification
Model6S8SWingspan1140mm /44.9 in1140mm /44.9 inOverall Length1320mm /52in1320mm /52inFlying WeightAround 3500gAround 3950gMotor Size3670-KV19504075-KV1500ESC120A120AServo13gX5pcs13gX5pcsServo23gX4pcs23gX4pcsRadio6CH Channel6CH ChannelCG (center of gravity)150–160mm150–160mmProp Size90mm 12-blade ducted fan90mm 12-blade ducted fanRecommended Battery22.2V 5000mAh-6000mAh 45c with EC5 connector29.6V 5000mAh-5500mAh 45c with EC5 connectorAileronYesYesRudderYesYesFlapsYesYesRetractsYesYesApprox. Flying Duration3 minutes3 minutesMinimum Age Recommendation14+14+Experience LevelIntermediateIntermediateAssembly Time10 minutes10 minutesWing Load119 g/dm2 (0.23oz/in2)134.3 g/dm2 (0.26oz/in2)Wing Area29.4dm2 (455.5 sq.in)29.4dm2 (455.5 sq.in)
RTF :(Ready to fly): A RTF plane includes the plane with the radio, receiver, battery, charger, motor, servos, retracts (if it has) and ESC already in place.
PNP:(Plug and Play) — A PNP foam plane includes the plane with the motor, servos, retracts (if it has) and ESC already in place. Battery and charger are not included. Radio and receiver are not included.
Notes to Buyers
Specification
| Model | 6S | 8S |
| Wingspan | 1140mm /44.9 in | 1140mm /44.9 in |
| Overall Length | 1320mm /52in | 1320mm /52in |
| Flying Weight | Around 3500g | Around 3950g |
| Motor Size | 3670-KV1950 | 4075-KV1500 |
| ESC | 120A | 120A |
| Servo | 13gX5pcs | 13gX5pcs |
| Servo | 23gX4pcs | 23gX4pcs |
| Radio | 6CH Channel | 6CH Channel |
| CG (center of gravity) | 150-160mm | 150-160mm |
| Prop Size | 90mm 12-blade ducted fan | 90mm 12-blade ducted fan |
| Recommended Battery | 22.2V 5000mAh-6000mAh 45c with EC5 connector | 29.6V 5000mAh-5500mAh 45c with EC5 connector |
| Aileron | Yes | Yes |
| Rudder | Yes | Yes |
| Flaps | Yes | Yes |
| Retracts | Yes | Yes |
| Approx. Flying Duration | 3 minutes | 3 minutes |
| Minimum Age Recommendation | 14+ | 14+ |
| Experience Level | Intermediate | Intermediate |
| Assembly Time | 10 minutes | 10 minutes |
| Wing Load | 119 g/dm2 (0.23oz/in2) | 134.3 g/dm2 (0.26oz/in2) |
| Wing Area | 29.4dm2 (455.5 sq.in) | 29.4dm2 (455.5 sq.in) |
PNP:(Plug and Play) - A PNP foam plane includes the plane with the motor, servos, retracts (if it has) and ESC already in place. Battery and charger are not included. Radio and receiver are not included.
KIT: A KIT plane is an airframe only. It does not include any motor, ESC, or servos (though usually includes servoless retracts on planes with retracts).
