We're continuing to fly the Foamaroo and are constantly amazed by what it will do. I wanted to try using a flat spin as a failsafe/abort system for the plane and actually tested by spinning it until it impacted the ground. My suspicions were correct - I was able to pick up and relaunch the plane after every flat spin and impact. Only damage was a slightly loose wingtip at the end of the day.
This method of recovery in the event of loss of control will not only protect the plane and its systems but would also protect anyone/thing on the ground in the unlikely event that it came down in a populated area.
Jimmy
Looks promising. A snap off release on the winglets, should prevent damage.
I would also do tests in strong winds to see that affects the spin.
Jimmy
TM =Telemetry, sending flight data over radio link, we use 2, Xbee s or 2, 3DRRadios transceivers. one for aircraft other one connects to laptop running the Mission Planner.
What's a "TM set"?
Jimmy,
Great alternate failsafe mode ! It will be useful for semi-flexable air frames, wonders what max sink rate is?
sounds like you could use a TM set?
That's the plan. My next step is to setup the failsafe on my radio and then turn it off with the plane over the landing area. Results should be exactly the same as in the video.
I don't have any means of measuring this plane so can't measure vertical acceleration. My try a data logger to see what it's doing. On a test earlier in the day I entered the abort maneuver at high speed, forgetting that I hand't taped on the nose cone. Got some great video of the nose cone coming off due to the high spin rate! All of the video that's in the spin test was also done with the nose cone simply stuck on (no tape) and didn't separate until the plane impacted.
Jimmy
Nice idea!
I guess what you're going to do is program the failsafe to go for pro-spin control surface deflections and hope it happens?
If you have an APM on board, perhaps you could log vertical acceleration and see what sort of spike you get on impact...? (or perhaps just add some code to store the maximum instantaneous acceleration values whilst the yaw rate exceeds some value - i.e. spinning?)
Thanks, Brakar. That's what we're hoping for.
Jimmy
