https://www.youtube.com/watch?v=ri53-myR2B4
FPV (first person view) flying from a park in Johannesburg, South Africa.
Aircraft stabilized with ArduPilot (+ thermopiles) with GPS "return to launch" safety switch. Camera has fisheye lens so height appears magnified, max height achieved during flight around 120m.
Video transmitted to ground via BOB Fox 700mW system and viewed/flown with video goggles, camera is Sony 420 line with tilt. Plane is twin boom pusher 148cm span, 1500mAh 3S LiPo, motor: EMax EF2812, 8x6 prop.
Safety was a primary concern hence the ArduPilot stabilized platform with RTL. There were also spotters watching the plane all the time, the flight stayed within 50m of the flying field "box" and not higher than 120m.
RCTx is a Hitec Aurora 9, one of the most robust AHFSS (frequency hopping spread spectrum) systems there is, previously tested to have a range of at least 2.65km at ground level! Plane is scratchbuilt twinboom.
Nice images Graham.
Keep in mind the safety concerns when flying over populated areas, though (something we shouldn't be doing).
Is that a scratchbuilt twin boom?
