3689392762?profile=original
Test Airframe: Senior Telemaster 8'
Boards:
APM
Oilpan
Arduino Pro
Freewave Radio
Eflight ESC & Motor
H264 Video Server
Joysticks that work:
Logitech G940 (no yaw on foot pedals yet) - Working on getting trim math working in the code.
Logitech Attack 3 (Tested all control surfaces working)
Other:
2 Cameras, 1 foward facing, 1 PTZ
Using Laptop with UBUNTU and Logitech Joysticks.
Phase 1:
a. Working Joystick Controls all surfaces of Airframe, Various buttons on Joystick change APM flight mode.
a. Completed
Added:
b. Working on integrating Logitech G940 Flight System
no yaw on foot pedals as off yet, does n't seem to show in the PYGAME librarys.
work to be done.
Phase 2: Complete
a. General Test - Live video through radio and video server.
b. Need to test and measure various bandwidth requirements for H264, frame sizes etc...
Phase 3: Complete
a. 4 Mile Test - 74db signal level Great video quality control surfaces respond instantly.
b. 15 mile test coming shortly.
Phase 4:Working on it.
Test GCS with waypoints.
Phase 5: Drop everything neatly back into airframe.
    Do you have any way of doing onboard recording? If so you could compare onboard and ground station recordings side by side to look for delay.
  • I found the issue with uploading video..   I am going to have to recapture some video with VLC,  I did some test captures and got the format worked out.....   So maybe after work today I can get some video posted.
    As far as the delay,  Anybody have any good ideas to measure that?   If I really pipe the resolution up, the delay is quite noticeable. .   640 x 480 and down things seem to be great.  Any thoughts?
  • @David Found a place to power it internally.....  As with everything else I have stripped off all the cases to save weight.  If you prefer not to mod anything pick up an axis 247S...
    Here is a picture of the inside of mine.3692179388?profile=originalAlthough this model states POE only that little green 4 position phoenix contact connector...left to right
    1 - GND
    2 - Power Output Can be used to power auxiliary equipment.12V DC, Max load = 50mA
    3 - Digital Input
    4 - Transistor Output
    If you give pins 1, 2 more than 11 volts it will power up the board.
    And you can do this without pulling the case off.
  • I don't know that particular motor so may be its quality is bad but I have been using other from the same source and disassembled some and the quality is not that bad at all. assuming that there is a QA difference, does that justify 15X the price?  in particular for brushless motor remember that a large part of the chinese population is using electric scooter for transportation so they really have the experience of huge volumes on that type of product. I have been spending time in China recently and I think more generally that we are underestimating the pace of their industrial improvement. of course you still have tons of low quality low cost "stuff" but they are also developing more and more pretty good and smart products. all that being said if you can afford it, a $600 motor is not that big a deal
  • I'm curious, how did you power the video encoder? From what I read, it appears to be powered over PoE (Power over Ethernet).
  • for such a project airframe design is key and especially 2 aspects : weight and drag. good designs can fly efficiently a payload as heavy as the airframe. 2 examples in full scale aviation. the cricri a full scale plane <170lb, cruise at 120mph range 280miles with 2x 20-30hp engines, and the arnold ar5 >210mph with 65HP! if you want long range why did you choose electric motor in the first place? anyway too many things to discuss on a forum thread... where is your base?
  • Yeah I need maximum efficiency for longer flight times. But the airframe and associated components are definitely not my specialty. So I am open to all suggestions.
  • 3692179304?profile=originalmy bad. I thought that the larger disk was some kind of planetary gear box. is the low KV/ huge propeller important for you?
  • Actually no gearbox on this motor....
  • in fact looking into it the axi is a 60 amp max which makes it a 2.2KW motor. equivalent motor here (HobbyKing Online R/C Hobby Store : TGY AerodriveXp 90 SK Series 50-... ) for a huge $39.99. now comes the problem of the KV. the AXI includes a gearbox most likely a 2:1. do you need to use such a bog prop? I know there is a little efficiency effect here but it is heavier and most of the time there is a lot more to gain on the aerodynamic design. if needed you can add a 2:1 timing belt system to keep your apparent 130 KV
