Freewing A-10 Thunderbolt II Super Scale Twin 80mm EDF Jet V2 PNP RC Airplane comes with twin outrunner brushless motors. and Twin 9-blade 80mm EDF Power Systems EDFs. For a list of full upgrades and amenities please see the features list below.
Northrop Grumman Officially Licensed Product
Renowned for its battlefield dominance and unmatched ground-attack capabilities, the A-10 Thunderbolt II V2, affectionately known as the 'Warthog,' has served for decades as the premier Close Air Support (CAS) aircraft. Honoring this legendary warbird, Freewing proudly presents the 80mm A-10 Thunderbolt II Version 2 the most advanced and definitive foam electric PNP A-10 ever created!
Building upon the success of its predecessor, this 1700mm wingspan model takes realism, durability, and performance to the next level. Quick-release main wings make assembly and transport effortless, while an upgraded plastic-cladded battery compartment improves long-term durability and better fitment for larger batteries. Glueless fuselage assembly and simplified wiring further simplifies construction, making this one of the easiest large EDF jets assemble and set up.
Scale realism is enhanced with scale, CNC-machined aluminum shock-absorbing struts and a fully detailed landing gear system with operational main and nose gear doors, ensuring smooth takeoffs and landings even on rougher fields. An upgraded LED lighting package, including a switchable, flashing LED armament effect, formation lights, and nose gear landing/taxi lights, increases visibility and adds an immersive touch to every flight.
Whether executing precision low passes, hard turns, or smooth landings, this model delivers an authentic and exhilarating EDF jet experience.
Screwless, Quick Release Wings
Enjoy effortless assembly and disassembly with the innovative quick release wing system.
Simulate Close Air Support (CAS) Runs!
A transmitter-switchable, flashing LED creates a muzzle-flash effect for enhanced realism and enjoyment.
Endless Personalization
3 different decal sets are included for easy customization or personalize it your own way with a custom, after-market decal set.
Realistic Scale Armament
Outfitted for battle, the A-10 includes a full armament package that attaches and removes effortlessly using a sliding rail system.
Brilliant Scale Lighting Package
Enhancing realism, the fully integrated lighting system includes formation (slime) lights, landing lights, navigation lights, strobe, and beacon lights for an authentic scale appearance both in the air and on the ground.
Scale Retracts with CNC-Machined Struts
Designed for ultimate realism, the A-10's retractable landing gear features painted CNC-machined shock-absorbing struts, providing a true-to-life appearance and smooth, scale operation.
High-Powered Twin 80mm EDF Power System
Equipped with twin 80mm 9-blade EDFs driven by powerful 3530-1900Kv Outrunner motors, this system delivers incredible thrust, high-speed capability, and strong vertical performance.
Massive Size
With an impressive 67 inch (1.7m) wingspan, the Freewing A-10 Thunderbolt II dominates the skies, delivering an unmistakable presence and scale realism that turns heads at any flying field.
Features:
- Freewing A-10 Thunderbolt II Super Scale Twin 80mm EDF Jet V2 PNP RC Airplane,Made in China Freewing Model in 2025
- NEW! Quick release main wings provide quick and easy field assembly and disassembly for convenient travel and storage
- NEW! Switchable, flashing LED that generates a muzzle flash effect for simulated close air support runs during flight
- NEW! Includes an enhanced and more accurate LED lighting package, including navigation lights, strobe, nose gear mounted landing lights as well as formation lights to further enhance scale realism
- NEW! Painted, scale, CNC-machined shock absorbing struts and added main gear doors further add to the realistic appearance
- NEW! Enlarged and plastic-cladded battery compartment accomodates larger batteries and provides enhanced durability
- NEW! Additional scale details, like the AAS-35 laser spot tracker and fuselage strakes are easily removed and secured with a sliding rail system, ensuring quick field assembly and damage-free transport
- NEW! Scale antenna and pitot tube details are designed for easy installation and removal with a simple press-fit system, allowing for hassle-free setup and damage-free transport
- NEW! Glueless assembly and simplified wiring provide a much faster and more convenient initial setup
- NEW! Reinforced motor pods provide a more secure, rock-solid attachment, ensuring improved stability and durability during flight
- NEW! Captured ball link control horns on the elevators center the ball linkage and provide an even load, maximizing responsiveness and long term durability
- Complete, scale armament package included that is easily installed and removed with a simple sliding rail system
- Includes 3 decal sets for easy customization or additional personalization with after-market, custom decals
- Thrust reversing capable ESC's enable shorter landings and greater ground control
- 2 units 3530-1900Kv outrunner motors combined with 9-blade 80mm EDF's provide incredible thrust
- Spring-loaded battery and electronics hatches for quick, hassle-free battery access
- Grass-ready retracts with metal trunnions and hardened steel pins
- Hand painted pilot figure adds a finishing touch to the scale detail
- Ball linkages on all control surfaces provide precise handling
- Long-lasting nylon hinges built for reliable performance
- Model officially licensed by Northrop Grumman
Includes:
- Freewing A-10 Thunderbolt II Super Scale Twin 80mm EDF Jet V2 - PNP RC Airplane
- 2 units 9-blade 80mm EDF Power Systems (installed)
- 2 units 3530-1900Kv Outrunner Motors (pre-installed)
- 2 units 100A ESC's with reverse thrust and EC5 connector (pre-installed)
- Electronic, retractable landing gear (pre-installed)
- All Servos (Pre-installed)
Requires:
- 6-8 Channel Radio (7 required for thrust reversing, 8 required for muzzle flash LED)
- 6-8 Channel Receiver (7 required for thrust reversing, 8 required for muzzle flash LED)
- 2 units 6 Cell 22.2V 5000 - 6000 mAh LiPo Batteries with EC5 Connectors
- 6 Cell Compatible Battery Charger - Select a minimum 6 cell (6S) charger
PRODUCT SPECIFICATIONS:
Model Scale |
1/10 |
Wingspan |
1700mm / 66.9in |
Length |
1551mm / 61.1in |
Flying Weight |
4.74kg / 10.45lb without batteries |
CG (Center of Gravity) |
78mm back from the leading edge of the wing root, with the aircraft upright and gear down |
Power System |
Electronic Speed Control |
2 x 100 Amp ESCs with thrust reversing and EC5 Connectors |
Propeller / EDF |
2x 80mm EDFs with 9 Blade Fans |
Servos |
Landing Gear |
CNC-Machined aluminum, shock absorbing, retractable landing gear |
Required Battery |
2 x 6S 22.2V 5000mAh - 6000mAh LiPo with EC5 Connector |
Required Radio |
6-8 Channels (8 required for thrust reversing and muzzle flash LED) |
Ailerons |
Yes |
Elevator |
Yes |
Rudder |
Yes |
Flaps |
Yes |
Lights |
Yes |
Hinge Type |
Nylon reinforced hinges |
Material |
EPO Foam |
Skill Level |
Advanced |
Build Time |
1 Hour |
Recommended Environment |
Outdoor |
Recommended Runway Surface |
Hard and soft surfaces, including maintained grass runways |
Freewing A-10 Thunderbolt II Super Scale Twin 80mm EDF Jet V2 PNP RC Airplane Flight Image:
To See More image
| Parts Number | Description | Image |
| FJ3111301 | Freewing Twin 80mm A-10 Thunderbolt II V2 Fuselage | ![]() |
| FJ3111302 | Freewing Twin 80mm A-10 Thunderbolt II V2 Main Wing Set | ![]() |
| FJ3111303 | Freewing Twin 80mm A-10 Thunderbolt II V2 Horizontal Stabilizer | ![]() |
| FJ3111304 | Freewing Twin 80mm A-10 Thunderbolt II V2 Vertical Stabilizer | ![]() |
| FJ3111305 | Freewing Twin 80mm A-10 Thunderbolt II V2 Vertical Stabilizer | ![]() |
| FJ31113082 | Freewing Twin 80mm A-10 Thunderbolt II V2 Nose Landing Strut and Wheel | ![]() |
| FJ31113013 | Freewing Twin 80mm A-10 Thunderbolt II V2 Cockpit | ![]() |
| FJ31113083 | Freewing Twin 80mm A-10 Thunderbolt II V2 Nose Shock Absorbing Rod | ![]() |
| FJ31113084 | Freewing Twin 80mm A-10 Thunderbolt II V2 Nose Support Rod | ![]() |
| FJ31113085 | Freewing Twin 80mm A-10 Thunderbolt II V2 Nose Anti-Torsion Arm | ![]() |
| FJ31113087 | Freewing Twin 80mm A-10 Thunderbolt II V2 Left Landing Strut and Wheel | ![]() |
| FJ31113089 | Freewing Twin 80mm A-10 Thunderbolt II V2 Right Landing Strut and Wheel | ![]() |
| FJ311130810 | Freewing Twin 80mm A-10 Thunderbolt II V2 Rear Shock Absorbing Rod | ![]() |
| FJ311130811 | Freewing Twin 80mm A-10 Thunderbolt II V2 Rear Supporting Rod | ![]() |
| FJ311130812 | Freewing Twin 80mm A-10 Thunderbolt II V2 Rear Anti-Torsion Arm | ![]() |
| FJ31113071 | Freewing Twin 80mm A-10 Thunderbolt II V2 Decal A | ![]() |
| FJ306110816 | Freewing 90mm F-16 V2 Wheel Axle | ![]() |
