Freewing Ares High performance Sport 3D 90mm Yellow 8S PNP RC Jet
The flight performance of the Freewing Ares 3D shocked us! The four-minute debut promotional video showcases what it can achieve. If we were to map the Ares's flight capabilities into a hexagonal radar chart, its performance could be adjusted via settings to cater to different technical demands. For this reason, we have temporarily decided against releasing a non-vectored thrust version. Our goal is to offer a single variant that can adapt to pilots of varying skill levels, allowing them to progress from beginner to advanced flight modes through different configurations.
Conventional Flight
By selecting a more forward center of gravity (CG) and disabling vector control (while keeping it powered to prevent accidental nozzle movement), the Ares can be flown like a conventional aircraft. In this mode, its flight characteristics remain gentle, closely resembling the flight experience of the Avanti, or even surpassing in some aspects (such as high-angle stall behavior).
Intermediate Flight
With a slightly aft CG and vector control enabled, along with adjustments to the vector-rudder and vector-elevator mixing, the aircraft becomes more agile, capable of performing various vectored maneuvers to enhance flight enjoyment.
3D Flight
For experienced 3D pilots, selecting an aft CG, enabling full vector control, and fine-tuning advanced mixing settings unlocks even more aerobatic maneuvers, delivering an exhilarating flight experience.
Electric Vector EDF Jet on Ares 3D
The breakthrough in vectoring technology laid a solid foundation for the Ares 3D Jet.
But this was just the beginning. Simulation of 3D models revealed the 80-class Ares fell far short of targets, prompting a redesign for the 90-class.
Features:
    • NEW! It is made with High quantity EPO Airframe
    • NEW! The PNP version has 120 Amp ESC with 8A UBEC
    • Sleek, aerodynamic design for incredible sport jet performance
    • Quick release main wings provide a simple and easy process for installing and removing the wings
    • NEW! Thrust Reversing function for shorter landings
    • NEW! Functional scale air brake for high alpha and help with shorter runways
    • Flight surfaces are controlled with 10 units 9g servos and 2 units 17g digital metal gear servos for precise movement, strength and long life
    • Bright 7 units LED lights for enhanced realism and dawn/dusk maneuvers
    • Electronic retractable landing gear with CNC shock-absorbing struts and metal trunnions
    • Scale, sequenced gear doors provide added realism and improved aerodynamics
Radio control toy airplanes
Jet aircraft models
Includes:
  • Freewing Ares High performance Sport 3D 90mm Yellow 8S PNP RC Jet
  • 4075-1350Kv Brushless Motor,12-Blade 90mm EDF system, 120A Electronic Speed Controller(ESC) with 8A UBEC,were pre-installed
  • All Servo,7 units LED lights, retracts and aluminum alloy Lading Gear Set pre-installed
  • 2 units  Freewing EG01 6-axis gyro pre-installed
Requires:
  • 8 Channel radio - select a minimum 8 channel radio
  • 8 Channel receiver - select a minimum 8 channel receiver
  • 6 Cell 22.2V 5000 - 6000 mAh Lipo Battery with EC5 connector
  • 90mm EDF Power Motor system and electronic speed controller (ESC).
  • 6 Cell compatible battery charger -please select a minimum 6 cell (6S) charger
SPECIFICATIONS:
Model ScaleN/A
Wingspan1156mm / 45.51in
Length
Edf radio control aircraft
1400mm / 55.11in
Empty Weight2350g
CG (Center of Gravity)215mm from the leading edge of the wing's root
Power System 4075-1350KV Brushless Motor(included)
Electronic Speed Control1 unit 120A Electronic Speed Controller(ESC) with 1 units 10A BEC ( included)
Propeller / EDF12-Blade 90mm EDF ( included)
Servos
  • 9g digital hybrid gear servo with 200mm lead : nose gear steering, landing gear door
  • 9g digital gear servo with 400mm lead : left canard, right canard
  • 9g digital hybrid gear servo with 500mm lead : rear cabin door left
  • 9g digital hybrid reverse gear servo with 500mm lead : rear cabin door right
  • 17g FSS digital metal gear servo with 100mm lead : rudder
  • 17g FSS digital metal gear servo with 300mm lead : left aileron, right aileron
Landing GearElectronic, CNC retractable scale gear
RequiYellow Battery6 Cell 22.2V 5000-6000 mAh LiPo Battery (not included)
RequiYellow Radio
Freewing RC airplanes
Jet aircraft models
8+ Channel (not included)
AileronsElevons
ElevatorElevons
RudderYes
FlapsNo
LightsYes
Hinge TypeNylon
MaterialEPO Foam
Skill LevelAdvanced/Expert
Build Time2 Hours
Recommended EnvironmentOutdoors
Freewing Ares 3D 90mm  EDF Sport Yellow Jet flight demo unboxing review
we will ship the package Box within 48 hours after the buyers pay money via paypal.
Freewing Ares 3D 90mm  EDF Sport Jet flight demo unboxing review
This Product is available in stock.
Freewing Ares 3D 90mm  EDF Sport Jet flight demo unboxing review Freewing Ares 3D 90mm  EDF Sport Jet flight demo unboxing review
