Freewing Eurofighter Typhoon V2 8S 90mm EDF with Gyro PNP JET
Freewing Eurofighter Typhoon V2 8S 90mm EDF Jet is one of the most capable multirole combat aircraft ever built. Developed through a partnership of European aerospace manufacturers, the Typhoon combines supercruise performance, advanced fly-by-wire flight control, and exceptional agility to serve as a front-line fighter for air forces across Europe and beyond. Its distinctive canard-delta configuration, sharply sculpted fuselage, and powerful twin-engine layout give the Typhoon one of the most aggressive silhouettes in modern military aviation.
The Freewing Eurofighter Typhoon 8S High Performance 90mm EDF Jet V2 builds on the acclaimed 2023 Freewing Eurofighter platform with a focused set of V2 upgrades — and pairs them with the power of an 8S system designed to push the Typhoon to its performance ceiling. The 8S power system — built around a 4075-1350Kv brushless inrunner motor, 12-blade 90mm EDF, and 120A ESC with thrust reversing — delivers top-end EDF performance with the turbine-like sound and serious speed that define this version of the aircraft.
The V2 release introduces quick-disconnect wings for faster, tool-free assembly and breakdown at the field, along with formation lights integrated into the existing scale LED package for enhanced visual presence during flight. The center of gravity range has been extended to allow a more aft CG setting, with CG reference marks now located on the wing for faster, easier field setup. The V2 also debuts an all-new livery: the striking XI(F) Squadron RAF 100th Anniversary scheme of ZJ925, with a medium grey airframe, black spine and a dramatic black tail bearing the DXI eagle. A factory-installed EG01 gyro stabilization system rounds out the update, adding confidence on approach and during precision maneuvering without removing any of the aircraft's high-performance character.
All the hallmarks of the 2023 Freewing Eurofighter carry forward into the V2: scale CNC shock-absorbing landing gear with painted struts, sequenced gear doors, a functioning linear-actuated airbrake, spring-loaded auxiliary air inlets, and a scale weapon set with ten pylons. For pilots who want the fastest, most aggressive version of this iconic jet, the 8S High Performance V2 is the definitive choice.
A Livery That Steals The Show
The Eurofighter doesn't just get an upgrade — it gets a whole new look. The 100th Anniversary scheme of ZJ925 flown by XI(F) Squadron RAF is one of the most visually arresting liveries ever applied to this airframe: medium grey fuselage, black spine, and a bold black tail dominated by the DXI eagle. It looks incredible in the air and even better on the ground.
Quick-Disconnect Wings
Getting to the flight line just got faster. The V2 Eurofighter's quick-disconnect wings make assembly and breakdown easier than ever. Tool-free and straightforward — spend less time setting up and more time flying.
Factory EG01 Gyro — Right Out of the Box
The factory-installed EG01 6-axis gyro stabilizes the flight envelope and adds precision on approach — making the Eurofighter more locked in without dulling any of its high-performance character.
Scale Lighting Package
When the sun goes down, the Eurofighter lights up. Navigation, landing, and formation lights are integrated across the airframe — scale placement, serious visual impact, and the kind of presence on the flight line that makes every pass worth watching.
Scale Details That Deliver
CNC shock-absorbing struts, sequenced gear doors, a functioning linear-actuated airbrake, and a full ten-pylon ordnance load — the kind of details that make you stop and look twice before it even leaves the ground.
The Eurofighter Silhouette
Few combat aircraft have a more commanding presence in the sky. The canard-delta configuration, sculpted twin-engine fuselage, and aggressive stance of the Typhoon are captured faithfully in this model — a jet that turns heads from the moment it rolls onto the runway.
Features:
  • NEW V2! Quick-disconnect wings allow fast, tool-free assembly and disassembly for convenient transport and field setup,made in Freewing model
  • NEW V2! Formation lights integrated into the scale LED package for enhanced visual presence in flight
  • NEW V2! Factory-installed EG01 6-axis gyro for a more refined, confidence-inspiring flight experience
  • NEW V2! Wing-mounted CG reference marks and an extended aft CG range make dialing in the optimal CG faster and easier than ever
  • NEW V2! Updated XI(F) Squadron RAF 100th Anniversary livery — ZJ925 scheme with black spine and dramatic black tail with DXI eagle
  • 8S power system with 3668-1980Kv brushless inrunner motor and 12-blade 90mm EDF delivers strong performance and realistic turbine sound
  • 120A ESC with thrust reversing function for shorter landing rollouts
  • Functioning scale airbrake on linear electric actuator for high-alpha maneuvers and post-landing deceleration
  • Scale CNC shock-absorbing retractable landing gear with grey-painted struts and metal trunnions
  • Scale sequenced gear doors for added realism and improved aerodynamics
  • Spring-loaded auxiliary air inlets open and close automatically to feed the EDF based on air pressure differential
  • Scale LED landing and navigation lights for enhanced realism
  • Scale weapon set and pylons (10 total) included
  • 9g and 17g digital metal gear servos for precise, reliable control response
  • Nylon hinges on all control surfaces
  • Upgraded pushrod clevis and metal ball head connectors throughout
Package Includes:
  • Freewing Eurofighter Typhoon 8S High Performance 90mm EDF Jet V2 with Gyro — PNP
  • Factory-installed 4075-1350Kv brushless inrunner motor with 12-blade 90mm EDF unit
  • Factory-installed 120A ESC with 8A UBEC and thrust reversing
  • Factory-installed EG01 6-axis gyro
  • Scale electric retractable landing gear with CNC struts and sequenced gear doors (installed)
  • Factory-installed digital metal gear servos
  • Scale LED navigation, landing, and formation lighting system (installed)
  • Instruction manual
Requires:
  • 7 Channel radio
  • 7 Channel receiver -
  • TWO 4 Cell 14.8V 5000 mAh LiPo batteries with EC5 connector
  • 6 Cell compatible battery charger
More info:Freewing Eurofighter Typhoon V2 8S 90mm EDF Jet with Gyro - PNP RC airplane,FJ31923PG, cheap wholesale Freewing Model Official Retail Store.
SPECIFICATIONS:
Model Scale
1/10.6
Wingspan
1030mm / 40.5in
Length
1450mm / 57in
Empty Weight
3230g (approx.)
CG (Center of Gravity)
215mm from the leading edge of the wing's root
Power System
4075-1350Kv Brushless Inrunner Motor (included)
Electronic Speed Control
120A with 8A UBEC and thrust reversing (included)
Propeller / EDF
12-Blade 90mm EDF (included)
Servos
  • 9g digital hybrid gear servo with 200mm lead : nose gear steering, landing gear door
  • 9g digital gear servo with 400mm lead : left canard, right canard -
  • 9g digital hybrid gear servo with 500mm lead : rear cabin door left
  • 9g digital hybrid reverse gear servo with 500mm lead : rear cabin door right
  • 17g digital metal gear servo with 100mm lead : rudder
  • 17g digital metal gear servo with 300mm lead : left aileron, right aileron
Landing Gear
CNC shock-absorbing retractable scale gear with metal trunnions (included)
Required Battery
6 Cell 22.2V 5000-6000mAh LiPo Battery with EC5 connector (required)
Required Radio
7+ Channel (required)
Ailerons
Elevons
Elevator
Elevons
Rudder
Yes
Flaps
No
Lights
Yes — Nav, Landing, Formation
Hinge Type
Nylon
Material
EPO Foam
Skill Level
Advanced/Expert
Build Time
3+ Hours
Recommended Environment
Outdoors
Recommended Runway Surface
Hard surfaces and short, well-manicured grass surfaces
https://www.freewingmodel.de/freewing-eurofighter-typhoon-v2-8s-high-performance-90mm-edf-jet-with-gyro-pnp-fj31923pg-rc-airplaneFreewing Eurofighter Typhoon v2  90mm EDF Jet
