Note:This is the High Performance 6S version which includes a 3668-1960Kv inrunner motor with 12-blade EDF and a thrust reversing 120A ESC. just add your own battery with EC5 Connector to begin flying.
in 2024,The Freewing F-16 V2 90mm EDF 6s PNP Jet from Freewing Model showcases a range of performance and design upgrades that elevate realism, flight capability, and convenience. Featuring a striking 64th Aggressors Livery, this model honors the distinguished 64th Aggressor Squadron, part of the legendary Aggressor program initiated in 1972. This squadron played a crucial role in training pilots through dissimilar air combat tactics, emulating potential adversaries.
With quick-release wings, an easier fuselage assembly, and a slide rail system for armament, the updated F-16C 90mm prioritizes ease of use. Additionally, the scale appeal and functionality have reached new heights with fully functional, servo-driven air brakes, updated scale details, extra molded-in rivets, painted landing gear, and other intricate detail components. The Freewing F-16C 90mm is designed to impress.
The new power system, featuring a 3668-1980Kv inrunner motor and a 12-blade EDF, delivers exceptional speed and power for long vertical climbs and rapid show passes over the runway. It also includes reverse thrust for short landing rollouts.
Experience the thrill and precision of the Freewing F-16 V2 90mm EDF is a true tribute to its full-scale counterpart, bringing advanced aerodynamics and stunning detail to your collection.
64th Aggressor Squadron Livery
Featuring an iconic 64th Aggressor Squadron livery, the Freewing F-16 V2 90mm JET showcases the legendary training unit.
Quick Release Wings
Enjoy effortless assembly and disassembly with the innovative quick release wing system.
Scale, Servo-Driven Airbrakes
Enhanced realism with fully functional, servo driven airbrakes that can be controlled from the transmitter.
Updated 3668-1980Kv Power System
Enhanced power and speed with the updated 3668-1980Kv inrunner motor and thrust reversing with the included 120A ESC.
Spring Loaded Cheater Holes
Equipped with spring loaded cheaters that actuate in flight for enhanced in flight performance while maintaining scale appeal on the ground.
Quick Attach Rail System for Armament
Easily install and remove armament with the updated quick attach rail system.
Added Scale Details
Extra molded-in rivets and detailed plastic components elevate the scale realism.
Larger Battery Compartment
Spacious battery compartment to easily accommodate various battery sizes and configurations for 6 or 8S LiPo systems.
Features:
it is 64th Aggressors Camo Livery: A striking, historically inspired camouflage design
it is with Power System: 3668-1980Kv Inrunner Motor with a 90mm 12-blade EDF
it has 120A Brushless ESC with 8A UBEC and Thrust Reversing: Provides reliable and efficient power management as well as thrust reversing capability
Screwless, Quick-Release Main Wings: For easy assembly and transport
Scale, Servo-Driven Air Brakes: Enhances scale realism and performance
Quick Attach Rail System: Simplifies fuel tank and armament attachment
Additional Molded-In Scale Rivet and Panel Details: Adds to the model's scale appeal and authenticity
Increased Battery Compartment Size: Accommodates larger batteries
Plastic Corner Protection: Around the battery compartment and fuselage chines for added durability
Additional Plastic Scale Details Included: Enhances the model's visual appeal
Spring-Loaded Cheater Holes: Improves power, speed, and overall performance
Stronger Landing Gear Mounts and Painted, CNC-Machined Landing Gear: Adds scale aesthetic appeal and adds durability
Spring-Loaded Battery Latch: Secures the battery with ease
Glueless Rear Fuselage Assembly: Simplifies the build process
Officially Licensed by Lockheed Martin
Sequenced gear doors provide added realism and reduced drag
Bright LED navigation and landing lights for enhanced realism and dawn/dusk maneuvers
Carbon fiber wing spars
Ball linkages on all control surfaces
Nylon hinges on all control surfaces
Package Box Includes:
Freewing RC Model Sources List
Freewing F-16 V2 90mm EDF Jet 8S PNP JET
Freewing F-16 V2 90mm EDF Jet 8S PNP Jet
Freewing F-16 V2 90mm EDF 6S PNP Jet
Freewing F-16 V2 90mm EDF ARF Plus Jet
Freewing Zeus V2 90mm 6S PNP Airplane
Freewing Zeus V2 90mm 6S PNP EDF Jet
Freewing Zeus V2 90mm 8S PNP Airplane
Freewing Zeus V2 90mm 8S PNP EDF JET Airplane
Freewing F-16 V2 High Performance 90mm EDF Jet - PNP
12-Blade EDF power system (installed)
The 3668-1980Kv brushless inrunner motor system (installed)
120A Brushless ESC with reverse thrusting and EC5 connector (installed)
Electronic retractable landing gear (installed)
All Servos, LED Lights are pre-installed
Requires:
6 Channel radio - select a minimum 6 channel radio (8 channels for thrust reversing and gyro mode function)
6 Channel receiver
6 Cell 22.2V 5000 mAh LiPo battery with EC5 connector
6 Cell compatible Lipo battery charger
Model Scale1/10 Scale
Wingspan955mm / 37.6in
Length1457mm /57.4in
Empty WeightEmpty Weight 3.17kg (7.0lbs) without battery and armament
CG (Center of Gravity)110mm (4.3") from the leading edge of the wing at the root
Power System3668-1980Kv Inrunner Motor
Electronic Speed Control120A Brushless with 8A UBEC, thrust reversing, EC5 Connector
Propeller / EDF90mm 12-Blade EDF
Servos
  • 9g hybrid digital standard with 300mm lead : nose gear steering
  • 9g hybrid digital standard with 400mm lead : nose gear door
  • 17g metal gear digital standard with 100mm lead : left rudder, right rudder
  • 23g metal gear digital reverse 100mm lead : right elevator
  • 23g metal gear digital standard 100mm lead : left elevator
  • 17g metal gear digital standard with 200mm lead : left flap, right flap
  • 17g metal gear digital standard with 300mm lead : left aileron, right aileron
Landing GearElectronic retractable main gear and steerable nose gear with all metal shock absorbing struts
Required Battery6S 22.2V 5000mAh LiPo with EC5 connector (required)
Required Radio6 Channel (required)
AileronsYes
ElevatorYes
RudderYes
FlapsNo
LightsYes
Hinge TypeNylon Reinforced
MaterialEPO Foam
Skill LevelIntermediate/Advanced/Expert
Build Time1 Hour
Recommended EnvironmentOutdoor, 150+ foot paved runway or short manicured grass
Freewing F-16 V2 90mm Fighting Falcon EDF Jet 6S PNP RC Airplane Manual Download:
Freewing F-16 V2 90mm Fighting Falcon EDF Jet 6S PNP RC Airplane Manual PDF Freewing F-16 V2 90mm Fighting Falcon EDF Jet 6S PNP RC Airplane
To See More images
