Freewing F-22 Raptor 70mm EDF Jet is designed to captivate with its scale realism and ease of use. Featuring highly detailed surfaces with molded-in panel lines and sequenced nose gear doors, this model delivers an authentic, visually stunning experience. The screwless, quick-release main wings make assembly and transport effortless, while CNC-machined aluminum shock absorbing struts help ensure smooth landings. Powered by a 12-blade 70mm EDF power system that offers reliable performance and precise control, the F-22 is perfect for pilots seeking both speed and agility in the air.
Whether you're a seasoned EDF pilot or looking to take your first steps into the world of jet-powered flight, the 70mm EDF F-22 delivers the performance, realism, and convenience you need to make every flight unforgettable.
Quick Release Wings Enjoy effortless assembly and disassembly with the innovative quick release wing system. |
Freewing RC Model Sources List
Freewing F9F Panther 70mm EDF Jet ARF Plus Jet
Freewing F9F Panther 70mm High Performance PNP EDF Jet
Freewing F9F Panther 70mm High Performance EDF Jet with Gyro PNP
Freewing Avanti S V2 80mm Yellow Sport Jet ARF Plus RC Airplane
Freewing Avanti S V2 80mm Yellow Sport EDF PNP Jet RC Airplane
Freewing F-22 Raptor 70mm EDF ARF Plus RC Jet
Freewing F-22 Raptor 70mm EDF Jet with Gyro PNP RC Jet
Freewing F-22 Raptor 70mm EDF Jet PNP RC Jet
Freewing F-16 V2 90mm EDF Jet 8S PNP Jet
Freewing F-16 V2 90mm EDF 6S PNP Jet
Freewing F-16 V2 90mm EDF ARF Plus Jet
Freewing Zeus V2 90mm 6S PNP EDF Jet
Freewing Zeus V2 90mm 8S PNP EDF JET Airplane
Freewing Zeus V2 90mm ARF Plus EDF JET Airplane
Freewing J-10A V2 90mm 8S EDF Jet PNP
Freewing J-10A V2 90mm 6S EDF Jet PNP
Freewing J-10A V2 90mm ARF Plus
Freewing A-10 Thunderbolt II V2 twin 64mm High Performance EDF Jet PNP Airplane
Freewing F-14 Tomcat Twin 64mm EDF Jet PNP RC Airplane
Freewing F-14 Tomcat Twin 64mm EDF ARF Plus RC Airplane
Freewing J-10A Vigorous Dragon 90mm Jet 8S PNP RC Airplane
Freewing J-10A Vigorous Dragon 90mm Jet 6S PNP RC Airplane
Freewing J-10A Vigorous Dragon 90mm Jet ARF Plus RC Airplane
FFreewing L-15 64MM 4S EDF Jet PNP RC Airplane
FFreewing L-15 64MM 6S EDF Jet PNP RC Airplane
Freewing Zeus 90mm EDF Sport 8s Jet PNP RC Airplane
Freewing Zeus 90mm EDF Sport 6S Jet PNP RC Airplane
Freewing Zeus 90mm EDF Sport ARF Plus RC Airplane
Freewing F-16 Falcon V3 6S 70mm EDF PNP
Freewing F-16 Falcon V3 6S 70mm EDF ARF Plus RC Airplane
Freewing F-16 V3 70mm EDF Jet - PNP RC Airplane
Freewing F-16 V3 70mm EDF Jet - ARF Plus RC Airplane
Freewing F-22 V2 Raptor 64mm EDF Jet PNP 4S RC JET
Freewing F9F Panther V2 64mm 4S Blue EDF PNP RC Airplan
Highly Detailed
Highly detailed surfaces with molded panel lines for a realistic appearance.
CNC-Machined Aluminum Struts CNC-machined aluminum shock absorbing struts accentuate the scale appearance and help you achieve smooth landings. |
Well-Protected Plastic corner protection located in key areas to help prevent hangar rash. |
Sequenced Nose Gear Doors Sequenced nose gear doors were added for enhanced scale realism and lower drag. |
Powerful Performer Impressive power and speed with the 2957-2210Kv inrunner motor, 12 blade EDF and thrust reversing with the included 80A ESC. |
Features:
- Screwless, quick-release main wings for easy assembly and transport
- CNC-machined aluminum shock absorbing struts accentuate the scale appearance
- Sequenced nose gear doors for enhanced scale realism
- Highly detailed surfaces with molded panel lines for a realistic appearance
- 12-blade 70mm EDF for powerful, smooth thrust
- 2957-2210Kv Inrunner Motor for high-performance speed and efficiency
- 80A ESC with thrust reversing, 7A UBEC and EC5 connector for advanced control
- Plastic corner protection located in key areas like intake leading edges, wing tips and the trailing edge of the fuselage to help prevent hangar rash
- Spring-loaded battery hatch for quick and easy battery access
- Carbon fiber wing spars for strength and light weight
- Ball linkages on all control surfaces for precise control
- Nylon hinges for long-lasting durability
Includes:
- Freewing F-22 Raptor High Performance 70mm EDF Jet with Gyro Flight Control PNP Jet
- 12-blade 70mm EDF Power System (installed)
- 2957-2210Kv Inrunner Motor (installed)
- 80A ESC with reverse thrust and EC5 connector (installed)
- Electronic, retractable landing gear (installed)
- Servos (installed)
Requires:
- 6-7 Channel radio (7 required for Reverse Thrust)
- 6-7 Channel receiver (7 required for Reverse Thrust)
- 6 Cell 22.2V 4000 mAh LiPo battery with EC5 connector
- 6 Cell compatible battery charger
Product Specifications:
Scale |
1/16 |
Wingspan |
816mm / 32.1in |
Length |
1150mm / 45.3in |
Weight |
1.74kg (3.83lbs) without battery |
CG (Center of Gravity) |
108mm from the leading edge of the wing at the root |
Power System |
2957-2210Kv Brushless In-Runner Motor |
Electronic Speed Control |
80 Amp with 7A UBEC and thrust reversing |
Propeller / EDF |
70mm 12-Blade |
Servos |
Landing Gear |
Retractable landing gear with CNC-machined aluminum, shock absorbing struts |
Required Battery |
6 Cell 22.2V 3500-5000mAh Li-Po battery with EC5 Connector |
Required Radio |
6-7 channels (7 required for thrust reversing) |
Ailerons |
Yes |
Elevator |
Yes |
Rudder |
Yes |
Flaps |
Yes |
Lights |
No |
Hinge Type |
Nylon |
Material |
EPO Foam |
Skill Level |
Intermediate |
Build Time |
1 Hour |
Recommended Environment |
Outdoor |
