Freewing F-22 Raptor 80mm EDF PNP Jet
The Freewing F-22 Raptor 80mm EDF PNP Jet captures the iconic presence of the world’s most advanced air superiority fighter with exceptional scale detail in a pilot-friendly design. This EDF jet delivers unparalleled realism and flight experience with features like molded-in panel lines, rivet details, and fully sequenced gear doors for a sleek, aerodynamic, and authentic look.
Designed for convenience and performance, the F-22 features screwless, quick-release wings for effortless assembly and transport. Its 12-blade 80mm EDF power system, paired with a high-performance 3658-2150Kv inrunner motor, ensures smooth, powerful thrust and breathtaking speed. Stability is enhanced with the pre-installed Freewing EG01 6-axis gyro, making this jet accessible to both experienced pilots and those new to EDF flying.
With shock-absorbing CNC-machined aluminum struts, spring-loaded battery access hatch, and colorful LED navigation lights, the Freewing F-22 Raptor is as practical as it is stunning. From precise aerobatics to smooth landings, every flight feels as advanced as the jet it replicates.
Whether you're a seasoned EDF pilot or looking to take your first steps into the world of jet-powered flight, the 70mm EDF F-22 delivers the performance, realism, and convenience you need to make every flight unforgettable.
Quick Release Wings,and Screwless
Enjoy effortless assembly and disassembly with the innovative quick release wing system.
It is Pre-Installed 6-Axis Gyro Inside
The Freewing EG01 6-axis gyro is included and pre-programmed providing a more stable and enhanced flying experience.it is easy to control.
Scale Detailing
Highly detailed surfaces with molded panel lines, rivets, and other details for a realistic appearance..
Tight Closing, Sequenced Gear Doors
Full gear doors, both inner, outer main gear and nose gear automatically sequenced for enhanced scale realism and reduced drag.
Well-Protected
Plastic corner protection is located in key areas to help prevent hangar rash and general wear and tear..
Complete LED Light Package
Full navigation lights, landing lights, and lighted heads up display (HUD) provide enhanced realism and visibility..
Features:
  • Screwless, quick-release main wings simplify assembly and transport
  • Freewing EG01 6-axis gyro provides a stable and enhanced flying experience
  • CNC-machined aluminum oleo struts for smooth, durable landings
  • Inner and outer gear doors are fully sequenced for reduced drag and enhanced scale appearance
  • LED navigation and landing lights improve visibility and enhance the scale appearance
  • Highly detailed surfaces with molded panel lines and rivet details elevate scale realism
  • Detailed cockpit with painted pilot figure and illuminated heads up display (HUD)
  • High-performance 12-blade 80mm EDF for powerful, smooth thrust with an authentic jet sound
  • 3658-2150Kv inrunner motor for high-performance, speed and efficiency
  • 100A ESC with 7A UBEC, thrust reversing and EC5 connector for advanced control
  • Plastic corner protection helps prevent hangar rash and wear
  • Spring-loaded battery hatch allows quick and easy battery access
  • Carbon fiber wing spars add strength while minimizing weight
  • Ball linkages on all control surfaces ensure precise control
  • Nylon hinges provide long-lasting durability
Includes:
  • Freewing F-22 Raptor 80mm EDF Jet with EG01 6-axis Gyro PNP RC Airplane
  • 12-blade 80mm EDF power system was pre-installed
  • 3658-2150Kv inrunner motor was pre-installed
  • 100A ESC with reverse thrust and EC5 connector were pre-installed
  • Electronic, retractable landing gear werepre- installed
  • all LED lightings were pre-installed
  • All Servos were pre-installed inside
Requires:
  • 6-8 channel radio (8 required for thrust reversing)
  • 6-8 channel receiver (8 required for thrust reversing)
  • 6S 22.2V 4000-5000mAh LiPo with EC5 Connector-
  • Minimum 6 Cell Battery Charger .
Product Specifications:
AGE LEVEL :14 and up
SKILL LEVEL :Intermediate
BUILD TIME :1 hour
Scale1/16
Wingspan935mm / 36.8in
Length1300mm / 51.2in
Flying Weight2530g / 89.2oz
CG (Center of Gravity)115mm from the leading edge of the wing at the wing root
Power System3658-2150Kv inrunner motor
Electronic Speed Control100A brushless with 7A UBEC and thrust reversing
Propeller / EDF80mm EDF with 12-blade fan
Servos
  • Nose gear steering
  • Nose gear door
  • Left and right aileron
  • Left and right flap, left and right rudder
  • Left elevator
  • Right elevator
  • Left main gear door
  • Right main gear door
Landing GearCNC-machined aluminum, shock absorbing, retractable landing gear
Required Battery6S 22.2V 4000-5000mAh LiPo with EC5 Connector
Required Radio6-8 channels (8 required for thrust reversing)
AileronsYes
ElevatorYes
RudderYes
FlapsYes
LightsYes
Hinge TypeNylon
MaterialEPO foam
Skill LevelIntermediate
Build Time1 Hour
Recommended EnvironmentOutdoor
Freewing F-22 Raptor 80mm EDF PNP Jet Flight Image
Freewing F-22 Raptor PNP 80mm ARF Plus EDF Jet
To See More image
