The Freewing F-35C Turbine Ready Jet
from: https://www.freewing-model.com/freewing-f-35c-turbine-ready-kit-s-rc-jet.html
Conversion Key Considerations
Turbine Engine Selection: Most micro-turbine conversions on foam airframes in this class utilize compact engines producing 35N to 45N of thrust (such as the Xicoy X45 or KingTech K-35 / K-45G3/G4).
Thermal Management: A dedicated double-walled stainless steel thrust tube is required to isolate exhaust heat from the EPO foam structure. The turbine installation bay typically requires heat-shield tape or ceramic coating inside the fuselage cavity.
Fuel & Center of Gravity (CG): Replacing the standard 6S LiPo battery with a kevlar or custom-molded fuel tank placed near the CG point ensures that balance remains consistent as fuel is consumed during flight.
Structural Reinforcement: High-speed loads and engine vibration require reinforcing key stress points—such as wing spars, landing gear mounts, and control horn surfaces—with carbon fiber strips or epoxy layup.
PRODUCT CATOGORY
