The Freewing Zeus 45NT Turbine 1200mm Wingspan Kit+ S RC Airplane is the latest sport jet offering from Freewing. Featuring a sporty and highly aerodynamic design, the Zeus is made in China Freewing model,s fastest sport jet yet, reaching speeds of 130 miles per hour (210 kmh) in level flight. Additionally, the red, grey and white livery offers an attractive, bold presence that can be seen easily in the skies. Impressively designed, the wings are glue and screw-free utilizing a quick release wing lock mechanism that makes installing and removing the wings a simple and quick experience.
Each control surface is managed by a 17 gram metal gear servo for quality and confidence.Offered in Kit Plus S version, , the Zeus promises to deliver the most powerful thrust-to-weight ratio of all the Freewing sport jets before it. Take to the skies and experience the incredible thrill and neck-turning speed of the Zeus!
Feel The Need For Speed
The Freewing Zeus 45NT Turbine 1200mm Wingsapn Kit+ S RC Airplane is the fastest sport jet developed by Freewing to date. the Zeus is sure to quench your thirst for acceleration.
Quick-Install Release Wings
The Freewing Zeus 45NT Turbine 1200mm Wingspan Kit+ S Jet features a screwless quick release wing design that makes field assembly and disassembly a breeze.
Slow Your Roll
The Freewing Zeus 45NT Turbine 1200mm Wingspan Kit+ S RC Airplane a thrust-reversing enabling a brake-like effect, effectively reducing your roll out on landings. This is especially useful on shorter, paved runways.
Grass Friendly
The Freewing Zeus 45NT Turbine 1200mm Wingsapn Kit+ S RC Airplane comes with CNC-machined struts with a trailing link design that can handle most reasonably-mowed grass fields with ease.
Navigation and Position Lights
The Freewing Zeus 45NT Turbine 1200mm Wingsapn Kit+ S RC Airplane features daylight-bright LED lights on the wing tips, top and bottom of the fuselage, as well as a landing light that is mounted on the nose gear strut.
Vivid Color Scheme
The color scheme on the Freewing Zeus 45NT Turbine 1200mm Wingsapn Kit+ S RC Airplane is bright and vivid, providing great visibility in all types of situations and conditions.
Full Landing Gear Doors
The Zeus has fully sequenced gear doors, including inner main gear doors for lower drag and better sport jet performance.
Features:
Sleek, aerodynamic design for incredible sport jet performance
Quick release main wings provide a simple and easy process for installing and removing the wings
CNC-machined landing gear struts with trailing link design for better grass-field operations
Daylight-bright LED lights located on the wing tips, top and bottom of the fuselage and a landing light on the nose gear strut
5 units 17g digital metal gear metal gear servos for all control surfaces
2 units 9g digital hybrid metal gear servos for nose gear steering and nose gear doors
2 units 23g digital metal gear metal gear servos for vertical stabilizer
full function Freewing Flight Stabilizer Gyro inside
Fully sequenced gear doors, including inner main gear doors for lower drag and better performance
Nylon hinges on all control surfaces
more info:https://www.freewing-model.com/freewing-zeus-45nt-turbine-rc-airplane.html
Model Scale |
Wingspan | 1200mm / 47.24in |
Length | 1450mm /57.1in |
Empty Weight | 3570g (w/o battery,(w/o oil and (w/o Engine) |
CG (Center of Gravity) | 120mm (4.7") from the leading edge of the wing at the root |
Turbine Engine System Suggestion | Xicoy X45,X60,SW55,kingTech K-30,kingTech K-45(not- installed) |
The capacity of the main fuel tank. | 1150CC |
The capacity of the Anti-bubble fuel tank. | 150CC |
Brake Control System. | ABS brake Control System |
Servos | 5 units 17g digital metal gear metal gear servos for all control surfaces 2 units 9g digital hybrid metal gear servos for nose gear steering and nose gear doors
Landing Gear | Electronic retractable main gear and steerable nose gear with all metal shock absorbing struts |
Required Battery | 2S 22.2V 4000mAh to 5000mAh LiPo with EC5 connector (not included) |
Required Radio | 6 Channel (required) |
Ailerons | Yes |
Elevator | Yes |
Rudder | Yes |
Flaps | Yes |
Lights | Yes |
Hinge Type | Nylon Reinforced |
Material | EPO Foam |
Skill Level | Intermediate |
Build Time | 1 Hour |
Recommended Environment | Outdoor, 150+ foot paved runway or short manicured grass |
Package details Include:
Electronic retractable landing gear (Pre-installed)
2 units fuel tank,and Flight Stabilizer Gyro (Pre-installed)
servos,landing gear retracts(Pre-installed),all Servos(Pre-installed)
It requires:
1,6 Channel Radio and 6 Channel Receiver.
2,Turbine Engine system
3, 22.2V 4000mAh to 5000mAh 2S Li-Po battery with EC5 Connector
